#88: FileIdentifier replaced when harvesting ISO 19139 metadata from WebDAV
Reporter: asedgmen | Owner: geonetwork-devel@lists.sourceforge.net
Type: defect | Status: new
Priority: major | Milestone:
Component: General | Version: v2.2.0 Final
Keywords: |
When harvesting ISO 19139 metadata records using WebDAV, GeoNetwork (GN)
replaces the original FileIdentifier UUID in the metadata record with a
new UUID. Metadata should not be altered during the harvest process.
Additionally, GN will blindly replace a previously harvested record in its
repository
if the time stamp has changed on the file being harvested. GN does not
check if the FileIdentifier in the updated record being harvested matches
the FileIdentifier in the corresponding record in the repository. This
results in GN containing the updated record with a FileIdentifier matching
the harvested source, although it upsets GN's internal record keeping as
it tracks the FileIdentifier in a separate column in the database,
populated during initial harvest.
Note: The original FileIdentifier is maintained in MEF based imports.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/88>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
