[GeoNetwork-devel] [GeoNetwork opensource Developer website] #885: Harvesting ESRI's big GeoPortal 1.1 gives errors
Reporter: johnh | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: minor | Milestone: v2.7.0
Component: General | Version:
Keywords: |
Harvesting ESRI's big GeoPortal version 1.1 at URL:
http://gptogc.esri.com/geoportal/csw/discovery?Request=GetCapabilities&service=CSW&AcceptVersions=2.0.2
gives the following errors in the harvesting history:
Error: Raised exception when searching: Invalid parameter value:
locator=Like
Class: OperationAbortedEx
Stack:
at: org.fao.geonet.kernel.harvest.harvester.csw.Harvester file:
Harvester.java line: 476 method: doSearch
Harvester.java line: 205 method: search
Harvester.java line: 92 method: harvest
at: org.fao.geonet.kernel.harvest.harvester.csw.CswHarvester file:
CswHarvester.java line: 226 method: doHarvest
at:
org.fao.geonet.kernel.harvest.harvester.AbstractHarvester$HarvestWithIndexProcessor
file: AbstractHarvester.java line: 381 method: process
at: org.fao.geonet.kernel.MetadataIndexerProcessor file:
MetadataIndexerProcessor.java line: 39 method: processWithFastIndexing
at: org.fao.geonet.kernel.harvest.harvester.AbstractHarvester file:
AbstractHarvester.java line: 409 method: harvest
at: org.fao.geonet.kernel.harvest.harvester.Executor file: Executor.java
line: 87 method: run
I'm running GN version 2.7 snapshot revision r8695 with ANZMEST
schemaplugins revision r8650.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/885&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Keywords: |
Comment(by fxp):
r9053 should solve that issue but I still have exception "An exception
occurred with no applicable code" on !GetRecords operation for the URL
provided.
<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2&quot;
xmlns:dc="http://purl.org/dc/elements/1.1/&quot; service="CSW" version="2.0.2"
resultType="results" outputFormat="application/xml"
outputSchema="http://www.isotc211.org/2005/gmd&quot; startPosition="1"
maxRecords="20">
   <csw:Query typeNames="gmd:MD_Metadata,csw:Record">
     <csw:ElementSetName>summary</csw:ElementSetName>
   </csw:Query>
</csw:GetRecords>
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/885#comment:1&gt;
Priority: minor | Milestone: v2.8.0
Keywords: |
Changes (by ianwallen):
  * milestone: v2.7.0 => v2.8.0
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/885#comment:2&gt;
