#894: Nightly Build 2012-05-06 fails to create metadata in Gui Widgets interface
Reporter: ByronCinNZ | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.7.0
Component: General | Version:
Keywords: |
When creating metadata in the Gui Widgets interface for the 2012-05-06
nightly build, I get the following error:
2012-05-07 12:11:07,354 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="error">
<message>Failed to compile stylesheet. 2 errors detected.</message>
<class>TransformerConfigurationException</class>
<stack>
<at class="net.sf.saxon.PreparedStylesheet"
file="PreparedStylesheet.java" line="176" method="prepare" />
<at class="net.sf.saxon.TransformerFactoryImpl"
file="TransformerFactoryImpl.java" line="139" method="newTemplates" />
<at class="de.fzi.dbs.xml.transform.CachingTransformerFactory"
file="CachingTransformerFactory.java" line="127" method="newTransformer"
file="CachingTransformerFactory.java" line="82" method="newTransformer" />
<at class="jeeves.utils.Xml" file="Xml.java" line="467"
method="transform" />
<at class="jeeves.utils.Xml" file="Xml.java" line="393"
<at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.java" line="752" method="dispatchOutput" />
file="ServiceManager.java" line="429" method="dispatch" />
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java"
line="744" method="dispatch" />
<at class="jeeves.server.sources.http.JeevesServlet"
file="JeevesServlet.java" line="208" method="execute" />
file="JeevesServlet.java" line="109" method="doGet" />
<skip>...</skip>
<at class="org.fao.geonet.monitor.webapp.WebappMetricsFilter"
file="WebappMetricsFilter.java" line="96" method="doFilter" />
<skip>...</skip>
<at
class="org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter"
file="MetricsRegistryInitializerFilter.java" line="29" method="doFilter"
<skip>...</skip>
Create metadata works okay for in the classic GN interface for this build
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/894>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
