#910: Harvester / WxS / broken
Reporter: fxp | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: v2.8.0
Component: General | Version:
Keywords: |
In trunk and 2.8.x, WxS harvester is broken due to new schema location and
relative path to xsl/conversion folder.
Maybe conversion XSL should be stored in schema folder instead of global
XSLTs (which are used in import metadata panel too).
Quick workaround:
* copy xsl/conversion in WEB-INF/data/xsl/conversion (when using default
data directory location)
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/910>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Dear all,
Also the CSW/ISO 2.0 harvester is broken. When I try to harvest any CSW, I receive the error saying: ISO date is null.
This applies for the trunk version. The stable is ok.
Does anybody have any idea where might be a problem?
Thanks a lot,
Tomas
On 23 May 2012 14:43, GeoNetwork opensource Developer website <trac_osgeo@anonymised.com> wrote:
Keywords: |
Quick workaround:
- copy xsl/conversion in WEB-INF/data/xsl/conversion (when using default
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
Ing. Tomas Kliment
Contact information:
Ph.D. student:
Slovak University of Technology
Faculty of Civil Engineering
Department of Theoretical Geodesy
Radlinskeho 11, block A, 5th floor
813 68 Bratislava 15, Slovakia
Tel: +421 259274 297
e-mail: tomas.kliment@anonymised.com
Ph.D. Internship - Junior Researcher:
The National Research Council
Institute of Marine Science, Venice, Italy
External consultant:
Polymedia S.p.A, KIT Digital Company
Joint Research Centre of European Commission, Ispra, Italy
Keywords: |
Comment(by josegar74):
Added patch to review
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/910#comment:1>
Keywords: |
Comment(by fxp):
Fixed in trunk commit b89243512b65ac5bbfc1bcd91de9dd95963a7437
XSL for WxS conversion are duplicated which is not so nice:
* xsl/conversion for metadata import
* schema_dir/iso19139/convert for OGC WxS harvester (with the target
schema option used)
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/910#comment:2>
Keywords: |
Comment(by awalsh):
Hi Francois,
Hope this fix gets into the GN 2.8.x branch as well once you have verified
it. Because currently I am testing off the GN 2.8.x branch + ANZMEST 2.8.x
extension.
Will save me having to do the workaround trick copying all the files
manually.
Andrew Walsh
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/910#comment:3>
Priority: blocker | Milestone: v2.8.1
Keywords: |
Changes (by ianwallen):
* milestone: v2.8.0 => v2.8.1
Comment:
Changes were back ported to 2.8.1 as part of Ticket #1233
Can this ticket be closed now?
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/910#comment:4>
