#923: remove direct ant dependency from build / use maven-antrun-plugin
Reporter: mprins | Owner: geonetwork-devel@…
Priority: major | Milestone: v2.9.0
Component: Catalog server | Version:
Keywords: build |
The current build depends on Ant being installed for both the `geonetwork-
main` as well as the `geonetwork-docs` artifacts.
Apache has provided the `maven-antrun-plugin` so that Ant does not have to
be installed separately.
Attached patch replaces the exec calls to the external ant with use of the
maven-antrun-plugin so this will work when ant is not installed.
Ticket URL: <https://trac.osgeo.org/geonetwork/ticket/923>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
