[GeoNetwork-devel] [GeoNetwork opensource Developer website] #933: Status window not apear in IE8
Reporter: ebleys | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.8.0
Component: General | Version:
Keywords: IE8 Other Actions Status |
In MS Internet Explorer 8 (IE8) the selection window for change of status
does not appear. (works OK in FireFox)
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/933&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Comment(by simonp):
Had a look at this in IE9 - its broken there too (black screen, dialog
briefly appears then disappears when you click on the screen). I could get
it to work when switching the compat mode of IE9 to IE9Standards (in F12
web tools) but unfortunately this appears to break other things in extjs
which seems to work in IE8 standards mode (this mode is forced in
xsl/header.xsl with a meta tag).
Could be time to replace ModalBox with something from the extjs lib or
alternatively upgrade to extjs 4? Both are reasonable tasks so maybe there
is another alternative....
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/933#comment:1&gt;
Comment(by simonp):
Actually there may be a lighter solution to add the missing js in IE9
according to:
http://stackoverflow.com/questions/5375616/extjs4-ie9-object-doesnt-
support-property-or-method-createcontextualfragme
Adding the js from that link and changing the meta tag to IE9 mode seems
to get everything working in IE9 (but obviously needs more testing).
And the bug was raised in IE8 which I don't have handy....
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/933#comment:2&gt;
Comment(by simonp):
Dug up an old laptop with XP and IE8 on it - slow but I can see the
problem and with the help of the MS debugging tools - have a fix. I'll
commit the fix for IE9 and IE8 and we'll see how things go from there.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/933#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: IE8 Other Actions Status
Changes (by simonp):
  * status: new => closed
  * resolution: => fixed
Comment:
Fixed in svn commits 9194 and 9195 for trunk and 2.8.x
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/933#comment:4&gt;
