#938: Distribution : TransferOptions : Name expressed as gmx:MimeFileType should
be gco:CharacterString
Reporter: ebleys | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: minor | Milestone: v2.8.0
Component: Metadata standards | Version:
Keywords: |
XML injection issue: CI_OnlineResource/name gets reset to gmx:MimeFileType
but it uses the fileTag as content (eg myDocument.doc).
a) these are clearly not MimeFileTypes => validation error
b) that is not the intent of this element
(should provide a text box to give the URL a useful title)
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/938>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Type: defect | Status: closed
Resolution: worksforme | Keywords:
Changes (by simonp):
* status: new => closed
* resolution: => worksforme
Comment:
My reading of the gmx:MimeFileType is that the mime type is present as a
type attribute - string content is the file name with that mime type. So
for example you should see something like:
<gmx:MimeFileType type="text/plain">MyDocument.txt</gmx:MimeFileType>
GeoNetwork uses this as a substitute for gco:CharacterString (which is
quite valid) so that searches can be made for records with content that
has a certain mime type. Since it's a valid substitution for
gco:CharacterString and it contains the content that would be in the
CharacterString anyway, it's a pretty light substitute and it should be
supported by any other packages that support ISO XSDs. It also adds a
useful search feature.
BTW: the mime type is calculated in update-fixed-info.xsl using a
configurable mime type package (see WEB-INF/mime-type.properties).
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/938#comment:1>
