#94: NS_ERROR_INVALID_POINTER in Oracle Internet Application Server
Reporter: ticheler | Owner: geonetwork-devel@lists.sourceforge.net
Type: defect | Status: new
Priority: major | Milestone:
Component: User interface (web) | Version:
Keywords: Oracle |
Dear Jeroen,
We deployed GeoNetwork 2.2.0 on Oracle Internet Application Server. In
principal it works fine. However, we found a bug in the harvesting
management. The exception NS_ERROR_INVALID_POINTER occurs in the script
xsl-transformer.js if the link "harvesting managment" is selected in the
administration page. The problem is, that the value of t.responseXML is
null. I fixed the problem for the Firefox 3.0 browser by introducing the
following lines of code:
if (t.responseXML == null)
parser = new window.DOMParser();
t.responseXML = parser.parseFromString(t.responseText,'text/xml');
Nevertheless, the problem still exists for MS Internet Explorer. I was not
able to find out the real reason of the problem. May be you will really
detect the error and find a better bug fix. The revised version of the
script xsl-transformer.js is attached to this email.
Kind regards,
Jürgen
Dr. Jürgen Seib
Deutscher Wetterdienst
TI1/K - IT-Koordination
Frankfurter Strasse 135
63067 Offenbach
Tel.: +49(69)8062-2609
EMail: juergen.seib@...535...
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/94>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
Hi Jurgen,
The explorer bug could be due to the old version of sarissa being used in 2.2.0 which was analyzed by Stephen Davies last year - could you check and see whether you are using 0.9.9.4 please? (The trunk has the latest one in it now thanks to Heikki I think - web/geonetwork/scripts/sarissa.js).
I've seen the Firefox problem you mention a few times in my travels but never had a real chance to try and solve it - in the few attempts at analyzing it that I made I think I saw the Ajax requests for the XML coming back with an unusual response code and no xml (in fact I don't think the server ever saw the request!). Haven't noticed it recently with the latest updates to Firefox (using 3.0.7 now) - but that's not terribly comforting!
What sub-version of Firefox 3 are you finding the problem with (eg. 3.0.3)?
Is the server actually receiving the request and producing the xml response?
Perhaps you can get Firebug onto this and give us a trace so we can attempt to track it down?
I couldn't get a repeatable test case and I fiddled with delays etc to try and see if I could change its behaviour but to no avail.
Simon
Reporter: ticheler | Owner: geonetwork-devel@anonymised.comsourceforge.net
Type: defect | Status: new Priority: major | Milestone: Component: User interface (web) | Version: Keywords: Oracle | ----------------------------------+-----------------------------------------
Dear Jeroen,
Kind regards,
Jürgen
Dr. Jürgen Seib
63067 Offenbach
EMail: juergen.seib@anonymised.com
