#940: ISO 19139 XML - unwanted replacement of codeList URLs - not polite
Reporter: ebleys | Owner: geonetwork-devel@…
Type: defect | Status: closed
Priority: major | Milestone: v2.8.0
Component: Metadata standards | Version:
Resolution: wontfix | Keywords:
Changes (by simonp):
* status: new => closed
* resolution: => wontfix
Comment:
Can't see how the codelist will get forced just on copy/paste import
(doesn't happen as far as I can see).
But from the rest of the ticket I think you must be editing the record and
doing a 'Check' (ie.validate) because the codelists attribute is forced by
the update-fixed-info.xsl file for the schema on edit, check/save if you
have automatic fixes enabled in the system config (and its on by default).
Edit,Check/Saving does that forcing because it assumes you are using the
codelist supplied with the schema for use in the editor. If you want to
use a different codelist then you should modify things as follows:
- convert your codelist from the CT_Codelist format to the GeoNetwork
codelist format for localization purposes if using the base iso19139
schema (see WEB-
INF/data/config/schema_plugins/iso19139/loc/eng/codelists.xml for
example). Or in the case of iso19139.anzlic or iso19139.mcp replace the
CT_Codelist file in the schema/resources/Codelists dir with your
CT_Codelist file. Or alternatively just add your extra codes to those
file(s).
- place the CT_Codelist file you are using somewhere in the schema dir
(usually schema/resources/codelists) and rewrite your codelist url to the
local file path of the CT_Codelist file using the oasis catalog for the
schema eg. in your case you'd need to map
http://adl.brs.gov.au/anrdl/resources/codeList/codeList20120313.xml to
wherever you put the codelist file (this is so the codelist validator can
find it when it runs)
- modify update-fixed-info.xsl to write the url of your codelist file into
the codelist attribute (ie. replace the standard one) in your case it's
obviously going to be http://adl.brs…/…
With regard to b), the codelist validator (a schematron) expects an XML
document in CT_Codelist catalog format - if you've followed the steps
above you will have that.
I'm closing the ticket with won't fix - reopen if any of the above doesn't
work - thanks.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/940#comment:1>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
