#946: Lucene index / always use analyzer
Reporter: fxp | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.9.0
Component: General | Version:
Keywords: |
Add a !LowerCaseKeywordAnalyzer class to index keywords as lowercase to
allow case insensitive searches, but seem adding
<Field name="keyword"
analyzer="org.fao.geonet.kernel.search.LowerCaseKeywordAnalyzer"/>
to config-lucene.xml doesn't work at all.
In LQB addRequiredTextField method this code seem preventing the analyzer
to be executed as keyword is not (and should not) defined in
tokenizedFieldSet, so for non tokenized fields seem the value is not
analyzed? (else condition calls textFieldToken that calls analyzer
properly):
if (!_tokenizedFieldSet.contains(luceneIndexField)) {
// TODO : use similarity when needed
TermQuery termQuery = new TermQuery(new Term(luceneIndexField,
searchParam));
BooleanClause clause = new BooleanClause(termQuery, occur);
query.add(clause);
else {
// tokenize searchParam only if tokenized when indexing
StringTokenizer st = new StringTokenizer(searchParam,
STRING_TOKENIZER_DELIMITER);
Analyzers should be used in all cases (tokenized or not).
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/946>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
