[GeoNetwork-devel] [GeoNetwork opensource Developer website] #953: Map title bar disappears when interactive resource is added through the search results
search results
Reporter: xzam | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.6.5
Component: Web Map Viewer | Version: v2.6.4
Keywords: Map Panel, Title Bar |
'''Problem:'''
The map title bar disappears (or in other words is reduced in height
significantly) when a interactive resource is added to the map following
the steps below.
'''Prerequisites:'''
- The main map is in hidden state
'''Steps to reproduce the behavior:'''
- locate a interactive resource in the search result panel
- add the resource to the map (the map should fade in and the new layer is
added)
- click on the button for hiding the map-panel (top-left corner)
- result should be that the title-bar of the map disappears. It´s not
possible to permanently display the mappanel afterwards because the button
for this is not visible/clickable anymore
(the attached image shows this status - marked with red)
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/953&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
search results
Comment(by xzam):
Here is a link to our geonetwork to reproduce the bug:
[http://131.220.109.2/geonetwork\]
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/953#comment:1&gt;
search results
Comment(by ianwallen):
In the file ./geonetwork/web/geonetwork/scripts/gn_search.js
If I remove the call to the following mainViewport.doLayout(); from the
addWMSLayer function it seems to fix the issue. Anyone know why doLayout
is required?
function addWMSLayer(layers) {
    Ext.getCmp("north-map-panel").expand();
// mainViewport.doLayout();
    GeoNetwork.mapViewer.addWMSLayer(layers);
Only tested on Firefox - Maybe it is required for other browsers?
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/953#comment:2&gt;
search results
      Type: defect | Status: closed
  Priority: major | Milestone: v2.9.0
Resolution: fixed | Keywords: Map Panel, Title Bar
Changes (by ianwallen):
  * status: new => closed
  * resolution: => fixed
  * milestone: v2.6.5 => v2.9.0
Comment:
Applied fix in commit f00b5fc35cde4dfbd3a61c2ff882efcda16e354e (master)
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/953#comment:3&gt;
search results
  Priority: major | Milestone: v2.8.1
  * milestone: v2.9.0 => v2.8.1
Comment:
Commit 357e53fc1d3acf12c2296d4362a4ca51b4963429 in 2.8 branch
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/953#comment:4&gt;
