[GeoNetwork-devel] [GeoNetwork opensource Developer website] #955: deleting schema plugin - seems to remove all other templates.
Reporter: ianwallen | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.8.0
Component: General | Version:
Keywords: |
Removing a schema after it has been installed seems to break the
templates.
Steps to reproduce from a fresh installation of geonetwork.
1 - Install plugin via web interface (administration -> Add a metadata
schema/profile) - in this case I used the one from the repository
schemaPlugins/trunk/iso19139.mcp
2 - add templates for new schema plugin that was uploaded.
3 - Also add templates for iso19139
4 - Going to Administration -> New metadata - shows list of the templates
- both from MCP and also from iso19139
5 - Remove plugin using web interface (administration -> Delete a metadata
schema/profile)
6 - Going to Administration -> New metadata - shows error "No templates
available, import metadata first." I was expecting to still see the
iso19139 templates?
7 - Adding a template for any of the remaining schema does not solve the
issue. (even though it said that they were added successfully and I can
see them in the database)
8 - re-installing the mcp pluging fixes the issue. All the templates were
working again.
Also noticed that removing a schema does not remove the templates that
were installed from the schema plugin.
Windows XP
Oracle 11G
Geonetwork 2012-06-12 nightly build 2.8 branch
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/955&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Keywords: |
Comment(by ianwallen):
I also noticed that if I add content before I delete the schema then after
the schema is deleted, searching for the content give me "XPathException :
Template iso19139.mcpBrief has not been defined"
Maybe it should not allow the removal of a schema if there is data
associated?
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/955#comment:1&gt;
Keywords: |
Comment(by simonp):
No templates are actually being deleted - the guiservice that generates
the list of templates to display actually calls an xslt to process the
results of a search for template records - this xslt fails because the
search returns template records that belong to the deleted schema and they
can't be processed.
However I think the guiservice could now use fast=index when it searches
for the template records and avoid this issue as this will provide all the
geonet:info fields it needs. I'll prepare a fix for this based on this
approach.
Can decide on whether to allow a schema to be deleted if records still
exist with that schema later (after 2.8.x maybe?).
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/955#comment:2&gt;
