#971: Cannot add subsequent keywords
Reporter: geomsp | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.8.0
Component: General | Version: v2.6.4
Keywords: |
We just installed the 2.8 version, and realized a problem whikle addind a
new keyword from the metadata form.
In 2.7, we could simply click the "+" button to add a keyword field.
In 2.8, the field is still generated, but when we try to save the
metadata, the '''content''' of the added fields are deleted. Only the
first one seems to stay.
The validation tool gives this:
error Element 'gmd:keyword' cannot have character [children], because the
type's content type is element-only. (Element: gmd:keyword with parent
element: gmd:MD_Keywords)
The bug seems to affect only the "handmade" keywords (those added using a
Thesaurus are ok).
Any idea about how to correct this minor, but very troubling problem?
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/971>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Keywords: |
Changes (by simonp):
* version: v2.6.4 =>
Comment:
In 2.8: gmd:keyword can have either a gco:CharacterString or gmx:Anchor
child.
When the gmd:descriptiveKeywords/gmd:MD_Keywords element is added,
gmd:keyword is a mandatory child and so it gets added but gmd:keyword
can't be added because the user has to choose whether it has a
gco:CharacterString or gmx:Anchor child first - so what is actually added
is a gmd:keyword without a child hence the removal of any text content
that you add to it and validation error.
This looks to be a bug in EditLib/fillElement
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/971#comment:1>
Keywords: |
Comment(by simonp):
Simple workaround for 2.8 would be to remove the suggestions for
gmd:keyword - this would return the behaviour to 2.7 and earlier versions.
However the problem will reoccur when someone adds a suggestion to a
mandatory element especially now that gmx:Anchor support is present.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/971#comment:2>
Keywords: |
Comment(by fxp):
It also happens with gmd:RS_Identifier/gmd:code
with the suggestion
<field name="gmd:code">
<suggest name="gco:CharacterString"/>
<suggest name="gmx:FileName"/>
<suggest name="gmx:Anchor"/>
</field>
only
<gmd:identifier>
<gmd:RS_Identifier>
<gmd:code/>
</gmd:RS_Identifier>
</gmd:identifier>
is created.
Due to the cardinality 1..1 one gmd:code is created but no child. There is
no workaround like keyword where you can still create new element, choose
a type and create the element.
The metadocument does not list the suggestion.
<gmd:RS_Identifier>
<gmd:code>
<geonet:element ref="76" parent="75" uuid="gmd:code_d9bcaa17-edbd-4006
-853d-fc617c49ddb0" min="1" max="1"/>
<geonet:attribute name="gco:nilReason" add="true">
<geonet:text value="inapplicable"/>
<geonet:text value="missing"/>
<geonet:text value="template"/>
<geonet:text value="unknown"/>
<geonet:text value="withheld"/>
</geonet:attribute>
</gmd:code>
We should get a geonet:choose element here ?
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/971#comment:3>
