#980: ExtJs apps lang files are compressed with wrong encoding
Reporter: landry | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: Future release
Component: User interface (web) | Version: v2.6.5
Keywords: encoding |
In the context of building geosource from trunk, the App-mini.js generated
file ends up with all utf-8 chars from web-
client/src/main/resources/apps/js/OpenLayers/lib/OpenLayers/Lang/fr.js
(and probably other langs) are replaced by '?' in the temporary
./target/classes/apps/js/GeoNetwork/lib/GeoNetwork/lang/fr.js file, and in
the yui-compressed App-mini.js file.
So all translations strings coming from extjs look broken, they end up in
the ui as ??, so for example on geosource homepage i get 'crit??res
avanc??es' instead of 'critères avancés'.
The easy fix i've found is to force yuicompressor-maven-plugin to use
utf-8 encoding :
Index: web-client/pom.xml
--- web-client/pom.xml (revision 9207)
+++ web-client/pom.xml (working copy)
@@ -78,6 +78,7 @@
<nosuffix>true</nosuffix>
<gzip>false</gzip>
<force>true</force>
+ <encoding>${project.build.sourceEncoding}</encoding>
<nomunge>true</nomunge>
<jswarn>${minify.verbose}</jswarn>
<excludes>
By default it seems yuicompressor is supposed to be in utf-8, but in my
environment it was not the case.
Note that i havent checked, but it seems only geosource/pom.xml defines
project.build.sourceEncoding, so it 'might' break geonetwork. We can
aswell hardcode utf-8 here, since all the lang files are in utf-8...
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/980>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Comment(by landry):
After a bit more digging... this is equivalent to passing
-Dfile.encoding=UTF-8 to maven, and fixes the issue for me. Otherwise, all
accentued/utf chars are replaced by ? in the generated .js.
ie for example in gn.libs.map.js
GeoNetwork.lang.fr={featureInfoTooltipTitle:"caract??ristique"
vs
GeoNetwork.lang.fr={featureInfoTooltipTitle:"caract<C3><A9>ristique" (utf-
display in vim, this one is correctly displayed in the browser)
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/980#comment:1>
Type: defect | Status: closed
Resolution: fixed | Keywords: encoding
Changes (by jesseeichar):
* status: new => closed
* resolution: => fixed
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/980#comment:2>
Priority: major | Milestone: v2.8.0 RC2
Component: User interface (web) | Version: v2.8.0RC1
Changes (by landry):
* version: v2.6.5 => v2.8.0RC1
* milestone: Future release => v2.8.0 RC2
Comment:
https://github.com/geonetwork/core-
geonetwork/commit/9c88deb7e6c01546b28ac04464ac4400e3d0cec1
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/980#comment:3>
