#989: GeoNetwork Z39.50 harvest stops half way through
Reporter: murrayh | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.6.5
Component: General | Version:
Keywords: |
We are attempting to harvest BRS using GeoNetwork's Z39.50 harvester and
it stops half way through.
We suspect that the harvester breaks when it encounters a duplicate
record. Debug log extract is below.
We can retrieve all of the records using GeoNetwork's own Remote Search
feature, so we don't think there is an issue with BRS's server.
Murray
2012-07-13 00:19:38,117 DEBUG [geonetwork.harvester] - Processing record
from server BRS and Australian Natural Resources Data Library (ANRDL)
2012-07-13 00:19:38,119 INFO [geonetwork.harvester] - - Adding metadata
with http://adl.brs.gov.au/anrdl/metadata_files/pe_brs90000004212.xml
2012-07-13 00:19:38,162 DEBUG [geonetwork.harvester] - Processing record
2012-07-13 00:19:38,164 INFO [geonetwork.harvester] - - Adding metadata
with http://adl.brs.gov.au/anrdl/metadata_files/pe_abares99001806.xml
2012-07-13 00:19:58,227 DEBUG [geonetwork.harvester] - There are 10
children in the results (1011 to 1020)
2012-07-13 00:19:58,227 DEBUG [geonetwork.harvester] - Processing record
2012-07-13 00:19:58,231 INFO [geonetwork.harvester] - - Adding metadata
with http://adl.brs.gov.au/anrdl/metadata_files/pe_abares99001791.xml
2012-07-13 00:19:58,514 DEBUG [geonetwork.harvester] - Processing record
2012-07-13 00:19:58,518 INFO [geonetwork.harvester] - - Adding metadata
with http://adl.brs.gov.au/anrdl/metadata_files/pe_brs90000004213.xml
2012-07-13 00:19:58,571 DEBUG [geonetwork.harvester] - Processing record
from server null
2012-07-13 00:19:58,571 ERROR [geonetwork.harvester] - JZKit could not
retrieve record - returned <error message="Unable to retrieve record 1013"
from server null
retrieve record - returned <error message="Unable to retrieve record 1014"
2012-07-13 00:19:58,572 DEBUG [geonetwork.harvester] - Processing record
from server null
2012-07-13 00:19:58,572 ERROR [geonetwork.harvester] - JZKit could not
retrieve record - returned <error message="Unable to retrieve record 1015"
from server null
retrieve record - returned <error message="Unable to retrieve record 1016"
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/989>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
