#99: FGDC metadata extension with online linkage causes ClassCastException
Reporter: mattblanchette | Owner: geonetwork-devel@lists.sourceforge.net
Type: defect | Status: new
Priority: critical | Milestone:
Component: General | Version: v2.2.0 Final
Keywords: FGDC, metextns, onlink, ClassCastException |
Attempting to add a FGDC metextns (Metadata Extension) element with an
onlink (Online Linkage) in the metadata edit forms causes the following
Error message:
Error[[BR]]
The requested operation could not be performed.[[BR]]
ClassCastException : java.util.ArrayList cannot be cast to
java.lang.String
Once these elements (<metextns><onlink/></metextns>) are added to an FGDC
metadata entry, it can no longer be opened for editing since it will
always throw this Error.
Error log shows that this Exception originated from the addValues method
of org.fao.geonet.kernel.EditLib class, which appears to be line 999 since
it performs a String cast:[[BR]]
text.setAttribute(Edit.Attribute.Attr.VALUE, (String) values.get(i));
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/99>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
Resolution: | Keywords: FGDC, metextns, onlink, ClassCastException
Comment (by mattblanchette):
Current workaround:
Add test in addValues method:
if( values.get(i) instanceof String ) {
Element text = new Element(Edit.Element.Child.TEXT, Edit.NAMESPACE);
elem.addContent(text);
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/99#comment:1>
Type: defect | Status: closed
Priority: critical | Milestone: v2.4.0 RC2
Resolution: fixed | Keywords: FGDC, metextns, onlink, ClassCastException
Changes (by ticheler):
* status: new => closed
* resolution: => fixed
* milestone: => v2.4.0 RC2
Comment:
Fixed and tested by Simon Pigot
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/99#comment:2>
