[GeoNetwork-devel] Geonetwork Persistent Identifier to Harvested records
Hi Craig,
Thanks! no problems. I have created a TRAC ticket http://trac.osgeo.org/geonetwork/ticket/523
on the Geonetwork trac site and attached the patch for review/testing.
Andrew Walsh
----- Original Message ----- From: "Craig Jones" <jonescc@anonymised.com>
To: "Mathew Wyatt" <mat@anonymised.com>; "Francois Prunayre" <fx.prunayre@anonymised.com>
Cc: "andrew walsh" <awalsh@anonymised.com>; "Mat Wyatt" <mathew.wyatt@anonymised.com>; <Xiangtan.Lin@anonymised.com>; "Pauline Mak" <Pauline.Mak@anonymised.com>; "Julia Martin" <Julia.Martin@anonymised.com>; "Sally Goodenough" <Sally.Goodenough@anonymised.com>; <ryan.fraser@anonymised.com>
Sent: Friday, June 03, 2011 10:23 AM
Subject: Re: Geonetwork Persistent Identifier to Harvested records
Hi All,
Hmm, I did offer I guess.
I've included a patch below to make the generation of uuids for WxS
datasets unique (geonetwork trunk).
I've tested this using WCS, WFS and WMS servers (and with the proposed
SOS option).
Is there an existing trac issue for this so I can attach the patch? If
not can someone create one (Andrew?).
Francois, any issues with this patch?
CraigJ
On Fri, 2011-05-27 at 13:05 +0800, Mathew Wyatt wrote:
Hi All,
> Hello Craig,
> 2011/5/19 Craig Jones <jonescc@anonymised.com>:
> > Hi Francois,
> > I think Andrew's main requirement is a for uuid for layers/feature
> > type/coverage metadata that doesn't change. I don't think it has
> > to be
> > derived from the DescribeFeatureType url. The metadata is
> > actually
> > harvested from the GetCapabilities statement and not the
> > DescribeFeatureType operation (although this would be an
> > interesting
> > extension perhaps for our mcp profile) and so its probably not a
> > good
> > match anyway.
> > Perhaps we could use the GetCapabilities url and append the layer
> > name/coverage name/feature type name as a way of indicating which
> > section of the GetCapabilities statement the metadata was
> > harvested from
> > (e.g add #feature-type-name to the getCapabilities url when
> > hashing).
> > I'm not sure that it matters really how the uuid is derived just
> > that
> > its consistent.
> Yep maybe this is a good option
> GetCapabilitiesURL#feature-type-name.
I like this solution too. Craig, are you happy to put together a
patch?
As for what happens at the ANDS harvest side, we are looking into the
solution you suggested Andrew, as to avoid getting orphaned records...
> > This would be an easy fix and would solve ANDS problem.
> > Happy to prepare a patch if this would help.
> > Have to say I'm very interested in your suggestion process for
> > extracting WMS extension etc when adding metadata. This would be
> > a
> > manual step when creating or editing metadata wouldn't it? i.e.
> > it
> > wouldn't be regularly updated during a harvest.
<snip>
