[GeoNetwork-devel] Geonetwork setup
Hi List,
I am pretty new to GeoNetwork. Have managed to install and configure the system to run.
I need to redesign the interface but I am failing to lacate the code that generate the html. I know its located in “/geonetwork/srv/en” folder but i cant find it on my machine.
Regards
Tiwonge R Machiwenyika
/web/geonetwork/xsl
The HTML is generated by XSLT, as you’ll see.
Good luck !
Heikki Doeleman
On Wed, Jan 14, 2009 at 11:38 AM, Tiwonge Machiwenyika <Tiwonge.Machiwenyika@anonymised.com> wrote:
Hi List,
Regards
This SF.net email is sponsored by:
SourcForge Community
SourceForge wants to tell your story.
http://p.sf.net/sfu/sf-spreadtheword
GeoNetwork-devel mailing list
Hi Tiwonge,
Just in few words, here you have the geonetwork mechanism.
Have a look to the config xml files under the WEB-INF repository, they define services your are accessing using url /geonetwork/srv/en/ANY_SERVICES (such as main.home).
These services return XML in output which is handled or not, depending on services, by xsl stylesheets.
So, if you want to modify the interface, have a look to the xsl files under the repository /web/geonetwork/xsl.
HTH,
Mathieu
On Wed, Jan 14, 2009 at 11:38 AM, Tiwonge Machiwenyika <Tiwonge.Machiwenyika@anonymised.com3…> wrote:
Hi List,
Regards
Mathieu Coudert
mcoudert@anonymised.com
Hi Tiwonge,
maybe you could take a look at the materials of the 2006 Geonetwork workshop at http://geonetwork-opensource.org/documentation/workshops/workshop-2006/geonetwork-opensource-workshop-april-2006
There are a couple of very good tutorials about interface costumization, I hope it helps you.
Víctor
Víctor Centella Fuster
Prodevelop, Integración de tecnologías
http://www.prodevelop.es
Servei d’Informàtica
Conselleria de Medi Ambient, Aigua, Urbanisme i Habitatge
Francesc Cubells 7, 46011 València
Tel.: 96 197 3942
Email: asistenciagis1_ctv@anonymised.com
http://www.cma.gva.es
----- Original Message -----
To: geonetwork-devel@anonymised.comists.sourceforge.net
Sent: Wednesday, January 14, 2009 11:38 AM
Subject: [GeoNetwork-devel] Geonetwork setup
Hi List,
Regards
