[Geonetwork-devel] GeoNetwork sources and build scripts
Hi Piero,
The sourcecode for both jeeves and for geonetwork are in their respective sourceforge projects CVS, so you should be able to check them out from there.
GeoNetwork has several branches, where the head is used to work towards version 2.1 and a 2.0.3 branch has just been created to add some minor fixes to GeoNetwork version 2.0.2
All scripts needed are available from the CVS, also the ANT build scripts are there to compile the source and also to generate an installer. The default one is in the root and the installer scripts are in the installer folder.
Good luck,
Jeroen
On Jul 20, 2006, at 11:02 AM, Piero Cavalieri wrote:
I think we have to put our hands a bit on the sources, because we have to integrate the geonetwork with our
.NET application. Could you provide me Ant script or exaplain me a bit how you build solution ?
Also, jeeves is broken in jeeves.resources.dbms.Dbms, if you want to connect to sql server (tried 2005).
In sourceforge there's only the binary jar, and I need the sources...
Thanks in advance
         Piero
Il contenuto di questo messaggio e' confidenziale e la lettura non
autorizzata dello stesso viola i diritti di privacy del mittente e del
destinatario.
Se avete ricevuto questo messaggio per errore siete pregati di
rimuoverlo dal Vostro sistema.
