[GeoNetwork-devel] GeoNetwork Stable Version Source
Hi All,
I have downloaded the latest Source from trunk, but there are some issues
with this source. I am not able to do INSPIRE search by using this source.
are there any bugs in this source?
I have taken the 2.6.4 version *geonetwork-install-2.6.4-0.exe* file and
installed it in my machine, with this I am able to do INSPIRE Search.
Can I get this version of Source in net for my development?
I have downloaded the 2.6.x source from SVN branch, with this source also I
am getting some script errors, is this is a stable version source?
Please help me in downloading stable version of GeoNetwork Source.
Thanks in advance.
Praveen Kumar A
Thanks & Regards,
Praveen
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GeoNetwork-Stable-Version-Source-tp6582932p6582932.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
hi Praveen,
to get the sources you need an SVN client, for example SmartSVN. Point it to GeoNetwork’s SVN repository at https://geonetwork.svn.sourceforge.net/svnroot/geonetwork.
Stable versions are tagged, for example to get the source of release 2.6.4 you should use tag ‘2.6.4’.
Hope this helps,
kind regards
Heikki Doeleman
On Thu, Jul 14, 2011 at 2:06 PM, Praveen <Praveenkumar.Anugandula@anonymised.com> wrote:
Hi All,
I have taken the 2.6.4 version geonetwork-install-2.6.4-0.exe file and
Thanks in advance.
Praveen Kumar A
Thanks & Regards,
Praveen
AppSumo Presents a FREE Video for the SourceForge Community by Eric
Ries, the creator of the Lean Startup Methodology on “Lean Startup
Secrets Revealed.” This video shows you how to validate your ideas,
optimize your ideas and identify your business strategy.
http://p.sf.net/sfu/appsumosfdev2dev
GeoNetwork-devel mailing list
