Support Requests item #1251896, was opened at 2005-08-04 15:52
Message generated for change (Tracker Item Submitted) made by Item Submitter
You can respond by visiting:
https://sourceforge.net/tracker/?func=detail&atid=533369&aid=1251896&group_id=72096
Please note that this message will contain a full copy of the comment thread,
including the initial issue submission, for this request,
not just the latest update.
Category: Metadata Editing Related Problems
Group: None
Status: Open
Priority: 5
Submitted By: Nils Jensen (nils_jensen)
Assigned to: Nobody/Anonymous (nobody)
Summary: Combobox "Schema" empty
Initial Comment:
Precondition:
I have installed Geonetwork 2.0.0 Beta 1 on my
Windows-Laptop to run in Tomcat and to access a remote
MySQL database. I have created the DB tables and
initial data with the SQL scripts.
Symptom:
After I login and try to "Import ISO19115 XML formatted
metadata" on the Web frontend, the Combo box "Schema"
is empty. The same symptom turns up when I try to
"Batch import". In accordance to my understanding, the
Combo box should have one entry for each schema.xsd
file in geonetwork\web\xml\schemas\. How do I get the
Combo box to show entries? The abovementioned directory
holds schemas for Dublin-Core, FGDC-STD, and ISO19115.
Thank you, Nils
