Support Requests item #1386526, was opened at 2005-12-20 15:26
Message generated for change (Tracker Item Submitted) made by Item Submitter
You can respond by visiting:
https://sourceforge.net/tracker/?func=detail&atid=533369&aid=1386526&group_id=72096
Please note that this message will contain a full copy of the comment thread,
including the initial issue submission, for this request,
not just the latest update.
Category: Installation Problems
Group: V2.0.0 Server
Status: Open
Priority: 5
Submitted By: lindsey (mlw_hou)
Assigned to: Nobody/Anonymous (nobody)
Summary: Can't install on JBoss 4.03 SP 1
Initial Comment:
I can't seem to get geonetwork to work correctly
outside of using included jetty or tomcat 5.5.12 (old
version).
I've tried using j2se 142 and 150 ... neither works.
Any hints would be greatly appreciated.
During jboss startup, the following error is reported:
15:09:52,871 INFO [STDOUT] 2005-12-20 15:09:52 | Found
handler : org.fao.geonet
.Geonetwork
15:09:52,901 INFO [STDOUT] 2005-12-20 15:09:52 | ---
Starting handler ---------
Initializing geonetwork...
Search...
15:09:53,338 INFO [STDOUT] 2005-12-20 15:09:53 |
Raised exception while startin
g appl handler. Skipped.
15:09:53,348 INFO [STDOUT] 2005-12-20 15:09:53 |
Handler : org.fao.geonet.
Geonetwork
Exception : javax.naming.Co
mmunicationException [Root exception is
java.io.NotSerializableException: com.k_
int.util.Repository.CollectionDirectory]
15:09:53,358 INFO [STDOUT] 2005-12-20 15:09:53 |
Message : null
15:09:53,368 INFO [STDOUT] 2005-12-20 15:09:53 |
Stack : javax.naming.Co
