Support Requests item #1478414, was opened at 2006-04-28 07:13
Message generated for change (Tracker Item Submitted) made by Item Submitter
You can respond by visiting:
https://sourceforge.net/tracker/?func=detail&atid=533369&aid=1478414&group_id=72096
Please note that this message will contain a full copy of the comment thread,
including the initial issue submission, for this request,
not just the latest update.
Category: Installation Problems
Group: None
Status: Open
Priority: 5
Submitted By: Nobody/Anonymous (nobody)
Assigned to: Nobody/Anonymous (nobody)
Summary: Problems starting Geonetwork 2.0.2
Initial Comment:
I have installed the las version of Geonetwork,
version 2.0.2 in our web server but I have problems
when we try to run it. So, can you see it and tell if
you had this problem and how could you solve it ?
http://gisweb.ciat.cgiar.org:8080/geonetwork/
Our network administrator replace de Java 1.4.1 for
1.5 in the web server, so I do not know if it could be
the problem....
Claudia Perea
c.perea@anonymised.com
CIAT
