Support Requests item #1735009, was opened at 2007-06-11 06:29
Message generated for change (Tracker Item Submitted) made by Item Submitter
You can respond by visiting:
https://sourceforge.net/tracker/?func=detail&atid=533369&aid=1735009&group_id=72096
Please note that this message will contain a full copy of the comment thread,
including the initial issue submission, for this request,
not just the latest update.
Category: Metadata Editing Related Problems
Group: None
Status: Open
Priority: 5
Private: No
Submitted By: Nobody/Anonymous (nobody)
Assigned to: Nobody/Anonymous (nobody)
Summary: Problem about Site ID, Templates and schemas
Initial Comment:
I have multiple problem whit my Geonetwork interface.
For first, the Site ID in the About page and the link page is not visible.
Secondly, my schemas and my templates are not available in administration panel.
I can not insert my metadata because i have an error.
i looked at my tomcat 5.5 logs file and under the "stdout.log" i have next errors:
Erreur1:
2007-06-05 03:58:21 | [main.present] (C) Exc : java.lang.NullPointerException
2007-06-05 03:58:21 | Raised exception while executing service
<error id="error">
<exception>
<message />
<string>java.lang.NullPointerException</string>
<stack>java.lang.NullPointerException
at org.fao.geonet.services.main.Result.exec(Result.java:66)
at jeeves.server.dispatchers.ServiceInfo.execService (ServiceInfo.java:238)
at jeeves.server.dispatchers.ServiceInfo.execServices(ServiceInfo.java:141)
at jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:375)
at jeeves.server.JeevesEngine.dispatch (JeevesEngine.java:614)
at jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:170)
at jeeves.server.sources.http.JeevesServlet.doGet(JeevesServlet.java:99)
at javax.servlet.http.HttpServlet.service (HttpServlet.java:689)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.apache.catalina.core.ApplicationFilterChain.doFilter (ApplicationFilterChain.java:173)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
at org.apache.catalina.core.StandardEngineValve.invoke (StandardEngineValve.java:107)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:199)
at org.apache.jk.common.HandlerRequest.invoke (HandlerRequest.java:282)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:767)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:697)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt (ChannelSocket.java:889)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
at java.lang.Thread.run(Thread.java:595)</stack>
</exception>
<request>
<language>fr</language>
<service>main.present</service>
</request>
<noResponse />
</error>
erreur2
2007-06-05 09:38:32 | Initializing schedules...
2007-06-05 09:38:32 | Initializing profiles...
2007-06-05 09:38:32 | Found handler : org.fao.geonet.Geonetwork
2007-06-05 09:38:32 | --- Starting handler --------------------------------------
2007-06-05 09:38:32 | Initializing geonetwork...
2007-06-05 09:38:32 | - Search...
2007-06-05 09:38:32 | - Access manager...
2007-06-05 09:38:32 | - Data manager...
2007-06-05 09:38:32 | Raised exception while starting appl handler. Skipped.
2007-06-05 09:38:32 | Handler : org.fao.geonet.Geonetwork
2007-06-05 09:38:32 | Exception : org.postgresql.util.PSQLException: ERROR: relation "metadata" does not exist
2007-06-05 09:38:32 | Message : ERROR: relation "metadata" does not exist
2007-06-05 09:38:32 | Stack : org.postgresql.util.PSQLException: ERROR: relation "metadata" does not exist
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java :1501)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1286)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:177)
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute (AbstractJdbc2Statement.java:430)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:346)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java :250)
at jeeves.resources.dbms.Dbms.executeQuery(Dbms.java:372)
at jeeves.resources.dbms.Dbms.select(Dbms.java:137)
at org.fao.geonet.kernel.DataManager.<init>(DataManager.java:78)
at org.fao.geonet.Geonetwork.start (Geonetwork.java:109)
at jeeves.server.JeevesEngine.initAppHandler(JeevesEngine.java:413)
at jeeves.server.JeevesEngine.init(JeevesEngine.java:136)
at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java :68)
at javax.servlet.GenericServlet.init(GenericServlet.java:211)
at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1105)
at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java :932)
at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:3951)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4225)
at org.apache.catalina.core.ContainerBase.start (ContainerBase.java:1013)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:718)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1013)
at org.apache.catalina.core.StandardEngine.start (StandardEngine.java:442)
at org.apache.catalina.core.StandardService.start(StandardService.java:450)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:709)
at org.apache.catalina.startup.Catalina.start (Catalina.java:551)
at sun.reflect.DelegatingMethodAccessorImpl.invoke (DelegatingMethodAccessorImpl.java:25)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:294)
I don't understand because my table exist and is complete.
Can you explain my what i be able to do it?
Thank you,
Jérome
