[GeoNetwork-devel] GeoNetwork Thumbnails in Database
Hekki Currently GeoNetwork stores Thumbnails (at least in my latest version) on the computer and not where the XML metadata is stored. my question: is there a way to store Thumbnails (pictures) in a database (same for the XML metadata) ? Thanks
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Hi
Not in the current code, but there’s an interface Store (https://github.com/geonetwork/core-geonetwork/blob/master/core/src/main/java/org/fao/geonet/api/records/attachments/Store.java) that is implemented by a class FileSystemStore: https://github.com/geonetwork/core-geonetwork/blob/master/core/src/main/java/org/fao/geonet/api/records/attachments/FilesystemStore.java
“Potentially” can be implemented a new class DatabaseStore that implements the interface Store and manages about the persistence and retrieval of the files attached to the metadata (not only thumbnails) in the database. I quote “potentially” as time ago I checked the code to implement a similar change, but was not that simple as other code outside of FileSystemStore relies also in file system for metadata files.
Jose García
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
Hello Jose
I looked the code a little bit.
It doesn't look impossible.
Will try to implement later on this summer.
Will let you know.
Thanks
Abel
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-developer-f3874395.html
