[GeoNetwork-devel] GeoNetwork Trunk Build in Eclipse
Hi All, I am recently started working on GeoNetwork. Installation of GeoNetwork is done properly by using geonetwork-install-2.6.4-0.exe, I am able to view the default worldmap. but when I added some other layers and turn on the Vector layers are not properly overlay on base map (see the enclosed image) Is this an issue with projection? how to resolve this? and another problem I am facing is… by using the instruction in the below URL I did the “Eclipse Setup” http://geonetwork-opensource.org/manuals/2.6.4/developer/GeoNetworkDeveloperManual.pdf but after this I am not able to understand how to proceed further. I am not able to get how to compile and deploy the GeoNetwork source into Tomcat. Is there a tutorial on how to compile a GeoNetwork (GN) trunk build in Eclipse? Thanks in advance, Praveen.
View this message in context: GeoNetwork Trunk Build in Eclipse
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Hi Praveen,
http://geonetwork-opensource.org/manuals/2.6.4/developer/development/index.html#eclipse-setup
Mathieu
EditLive Enterprise is the world’s most technically advanced content
authoring tool. Experience the power of Track Changes, Inline Image
Editing and ensure content is compliant with Accessibility Checking.
http://p.sf.net/sfu/ephox-dev2dev
GeoNetwork-devel mailing list
Hi Mathieu,
Thanks for quick response,
Already I did this setup, Now my Eclipse project looks like this.
For this source I want to apply some changes, then how to compile the source, deploy in tomcat and run the GeoNetwork from tomcat with the modifications/changes that I did to the source.
I would like to use PostGres database, I would like to add my own layers to the map, how should I configure the database to the GeoNetwork source.
Thanks & Regards,
Praveen.
Hi Praveen,
Mathieu
Hi Praveen,
I’m finding the information on:
http://lab.usgin.org/groups/geonetwork-configuration-and-development/windows-7-64-bit-guide-geonetwork-development-within
quite handy for checking out source from svn into eclipse and then creating the maven package and maven install from eclipse (even though I’m in Windows XP - I’m just doing everything in 32bit). I haven’t got to the bit about Deploying to Tomcat 6 or 7 and Debugging from within Eclipse, but that’s my next step - so far everything else in the instructions has worked. Hopefully this is correct (my disclaimer) and useful to you.
Melanie
On Wed, Jun 8, 2011 at 11:53 PM, Praveenkumar Anugandula <Praveenkumar.Anugandula@anonymised.com> wrote:
Hi Mathieu,
Thanks & Regards,
Praveen.
From: Mathieu Coudert [mailto:mathieu.coudert@anonymised.com]
Sent: Wednesday, June 08, 2011 7:11 PM
To: Praveenkumar Anugandula
Cc: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] GeoNetwork Trunk Build in Eclipse
Hi Praveen,
Mathieu
DISCLAIMER:
This email may contain confidential information and is intended only for the use of the specific individual(s) to which it is addressed. If you are not the intended recipient of this email, you are hereby notified that any unauthorized use, dissemination or copying of this email or the information contained in it or attached to it is strictly prohibited. If you received this message in error, please immediately notify the sender at Infotech or Mail.Admin@anonymised.com and delete the original message.
