Hi Maël,
Sounds like you're making progress.
Blocking while the Lucene index rebuilds is normal. You just need to wait it
out. It can take 1-15 minutes depending on number of metadata records in
database. I have ~2000 records and expect the first time startup to take
around 12 minutes.
Geonetwork uses Lucene to maintain keyword indexes of the metadata. Searching
Geonetwork uses the indexes to locate matching metadata records. The indexes
themselves can be regarded as temporary sequential files. If you delete them
they will be rebuilt the next time Geonetwork starts up (as you have found).
Did the server start following the index rebuild?
Stephen
-----Original Message-----
Sent: Thursday, 30 October 2008 3:30
To: Davies Stephen
Subject: RE: [GeoNetwork-users] Can't make Tomcat 5.5 and GeoNetwork
2.2.0worktogether [SEC=UNCLASSIFIED]
That sounds really better but now it blocks on rebuilding index for lucene.
See below :
geonetwork.log
2008-10-29 17:19:06,203 INFO [jeeves.engine] - === Starting system
2008-10-29 17:19:06,218 INFO [jeeves.engine] - Java version : 1.5.0_12-b04
2008-10-29 17:19:06,218 INFO [jeeves.engine] - Java vendor : Sun
Microsystems Inc.
2008-10-29 17:19:06,265 INFO [jeeves.engine] - XSLT factory :
org.apache.xalan.transformer.TransformerIdentityImpl
2008-10-29 17:19:06,265 INFO [jeeves.engine] - Path : D:\tmp\geonetwork\/
2008-10-29 17:19:06,265 INFO [jeeves.engine] - BaseURL : geonetwork
2008-10-29 17:19:06,265 INFO [jeeves.engine] - Loading :
D:\tmp\geonetwork\/WEB-INF/config.xml
2008-10-29 17:19:06,421 INFO [jeeves.engine] - Initializing general
configuration...
2008-10-29 17:19:06,421 INFO [jeeves.engine] - Initializing defaults...
2008-10-29 17:19:06,421 INFO [jeeves.engine] - Default local is :true
2008-10-29 17:19:06,437 INFO [jeeves.engine] - Initializing resources...
2008-10-29 17:19:06,437 INFO [jeeves.engine] - Adding resource : main-db
2008-10-29 17:19:06,437 INFO [jeeves.engine] - Loading activator :
org.fao.geonet.activators.McKoiActivator
2008-10-29 17:19:06,437 INFO [jeeves.engine] - Starting activator :
2008-10-29 17:19:08,215 INFO [jeeves.engine] - Initializing services...
2008-10-29 17:19:08,215 INFO [jeeves.engine] - Adding service : main.home
main.search
2008-10-29 17:19:08,231 INFO [jeeves.engine] - Adding service :
main.simple.search
main.search.embedded
main.present.embedded
main.searchform.advanced.embedded
main.searchform.simple.embedded
rating.popup
main.present
remote.show
2008-10-29 17:19:08,231 INFO [jeeves.engine] - Adding service : feedback
2008-10-29 17:19:08,231 INFO [jeeves.engine] - Adding service : links
2008-10-29 17:19:08,231 INFO [jeeves.engine] - Adding service : about
xml.region.get
2008-10-29 17:19:08,246 INFO [jeeves.engine] - Adding service :
feedback.insert
2008-10-29 17:19:08,246 INFO [jeeves.engine] - Adding service : util.ping
util.import
2008-10-29 17:19:08,246 INFO [jeeves.engine] - Adding service : user.list
2008-10-29 17:19:08,246 INFO [jeeves.engine] - Adding service : user.get
user.update
user.remove
user.pwedit
user.pwupdate
2008-10-29 17:19:08,262 INFO [jeeves.engine] - Adding service :
user.infoedit
user.infoupdate
group.list
2008-10-29 17:19:08,262 INFO [jeeves.engine] - Adding service : group.get
group.update
group.remove
xml.group.update
category.list
category.get
category.update
category.remove
xml.category.update
user.login
2008-10-29 17:19:08,278 INFO [jeeves.engine] - Adding service :
user.logout
2008-10-29 17:19:08,278 INFO [jeeves.engine] - Adding service : admin
2008-10-29 17:19:08,278 INFO [jeeves.engine] - Adding service : config
xml.config.get
xml.config.set
localization
xml.operation.update
xml.region.update
2008-10-29 17:19:08,278 INFO [jeeves.engine] - Adding service : help
xml.schema.info
file.disclaimer
file.download
graphover.show
resources.get
2008-10-29 17:19:08,293 INFO [jeeves.engine] - Adding service :
resources.upload
file.upload
resources.del
csv.search
selection.search
xml.user.login
xml.user.logout
xml.search
xml.metadata.get
2008-10-29 17:19:08,309 INFO [jeeves.engine] - Adding service : xml.info
xml.forward
xml.user.list
xml.group.list
xml.metadata.insert
xml.metadata.delete
2008-10-29 17:19:08,309 INFO [jeeves.engine] - Adding service : csw
2008-10-29 17:19:08,309 INFO [jeeves.engine] - Adding service : oaipmh
rss.latest
rss.search
rss.present
google.kml
mef.import
2008-10-29 17:19:08,324 INFO [jeeves.engine] - Adding service :
mef.export
xml.relation.get
xml.relation.insert
xml.relation.delete
resource.get
2008-10-29 17:19:08,324 INFO [jeeves.engine] - Initializing schedules...
2008-10-29 17:19:08,324 INFO [jeeves.engine] - Loading :
D:\tmp\geonetwork\/WEB-INF/config-metadata.xml
2008-10-29 17:19:08,340 INFO [jeeves.engine] - Initializing services...
2008-10-29 17:19:08,340 INFO [jeeves.engine] - Adding service :
metadata.insert
metadata.show
2008-10-29 17:19:08,356 INFO [jeeves.engine] - Adding service :
metadata.show.embedded
metadata.show.tab
metadata.edit
metadata.edit.tab
metadata.edit.frame
metadata.elem.add
metadata.xslupdate
metadata.xlink.add
metadata.elem.delete
metadata.update
metadata.update.tab
metadata.update.finish
metadata.update.validate
metadata.elem.down
metadata.elem.up
2008-10-29 17:19:08,371 INFO [jeeves.engine] - Adding service :
metadata.attr.add
metadata.attr.delete
metadata.delete
metadata.massiveDelete
metadata.create.form
metadata.duplicate.form
metadata.create
metadata.create.tab
metadata.create.service
metadata.admin.form
metadata.admin
metadata.admin.index.rebuild
metadata.category.form
metadata.category
2008-10-29 17:19:08,387 INFO [jeeves.engine] - Adding service :
metadata.xmlinsert.form
metadata.batchimport.form
metadata.searchunused.form
metadata.select
metadata.update.child
metadata.thumbnail.form
metadata.thumbnail.set
2008-10-29 17:19:08,402 INFO [jeeves.engine] - Adding service :
metadata.thumbnail.unset
2008-10-29 17:19:08,418 INFO [jeeves.engine] - Adding service :
transfer.ownership
xml.ownership.editors
xml.ownership.groups
xml.ownership.transfer
xml.metadata.rate
metadata.bbox.estimate
2008-10-29 17:19:08,418 INFO [jeeves.engine] - Loading :
D:\tmp\geonetwork\/WEB-INF/config-harvesting.xml
2008-10-29 17:19:08,434 INFO [jeeves.engine] - Initializing services...
2008-10-29 17:19:08,434 INFO [jeeves.engine] - Adding service :
harvesting
xml.harvesting.get
xml.harvesting.add
xml.harvesting.update
xml.harvesting.remove
xml.harvesting.start
xml.harvesting.stop
xml.harvesting.run
xml.harvesting.info
2008-10-29 17:19:08,449 INFO [jeeves.engine] - Loading :
D:\tmp\geonetwork\/WEB-INF/config-portal.xml
2008-10-29 17:19:08,449 INFO [jeeves.engine] - Initializing services...
2008-10-29 17:19:08,449 INFO [jeeves.engine] - Adding service :
portal.search
portal.opensearch
portal.search.keywords
portal.present
portal.search.present
2008-10-29 17:19:08,465 INFO [jeeves.engine] - Adding service :
portal.get
portal.full
portal.latest.updated
portal.featured
portal.categories
portal.sources
pdf.search
kml.search
2008-10-29 17:19:08,465 INFO [jeeves.engine] - Loading :
D:\tmp\geonetwork\/WEB-INF/config-export.xml
2008-10-29 17:19:08,465 INFO [jeeves.engine] - Initializing services...
2008-10-29 17:19:08,465 INFO [jeeves.engine] - Adding service : dc.xml
2008-10-29 17:19:08,465 INFO [jeeves.engine] - Adding service : fgdc.xml
iso19115to19139.xml
iso19139.xml
iso_arccatalog8.xml
iso19115.pdf
iso19139.pdf
iso19139.pdf.discovery
iso19139.pdf.essential
iso19110.essential
D:\tmp\geonetwork\/WEB-INF/config-thesaurus.xml
keywords.getselected
2008-10-29 17:19:08,480 INFO [jeeves.engine] - Adding service :
keywords.sort
keywords.select
keywords.search
xml.keyword.get
xml.search.keywords
xml.search.keywordlink
keywords.editsearch
thesaurus.admin
thesaurus.upload
thesaurus.download
thesaurus.delete
2008-10-29 17:19:08,496 INFO [jeeves.engine] - Adding service :
thesaurus.view
thesaurus.add
thesaurus.edit
thesaurus.update
thesaurus.editelement
thesaurus.addelement
thesaurus.updateelement
thesaurus.deleteelement
2008-10-29 17:19:08,496 INFO [jeeves.engine] - Loading :
D:\tmp\geonetwork\/WEB-INF/config-contact.xml
2008-10-29 17:19:08,512 INFO [jeeves.engine] - Initializing services...
2008-10-29 17:19:08,512 INFO [jeeves.engine] - Adding service :
contactdirectory.admin
contactdirectory.upload
contactdirectory.download
contactdirectory.delete
contactdirectory.view
contactdirectory.edit
contacts.newelement
contacts.duplicateelement
contacts.updateelement
contacts.viewelement
contacts.saveelement
2008-10-29 17:19:08,527 INFO [jeeves.engine] - Adding service :
contacts.deleteelement
contacts.sort
contacts.select
contacts.search
contacts.editsearch
2008-10-29 17:19:08,527 INFO [jeeves.engine] - Loading :
D:\tmp\geonetwork\/WEB-INF/config-crs.xml
2008-10-29 17:19:08,527 INFO [jeeves.engine] - Initializing services...
2008-10-29 17:19:08,527 INFO [jeeves.engine] - Adding service : crs.admin
crs.select
crs.upload
crs.download
crs.delete
2008-10-29 17:19:08,543 INFO [jeeves.engine] - Adding service : crs.view
2008-10-29 17:19:08,543 INFO [jeeves.engine] - Adding service : crs.edit
crs.update
crs.addelement
crs.deleteelement
crs.editsearch
crs.editsearchresults
crs.listsearchresults
crs.search
2008-10-29 17:19:08,543 INFO [jeeves.engine] - Loading :
D:\tmp\geonetwork\/WEB-INF/config-test.xml
2008-10-29 17:19:08,543 INFO [jeeves.engine] - Initializing services...
2008-10-29 17:19:08,543 INFO [jeeves.engine] - Adding service : test.i18n
test.i18n.xml
2008-10-29 17:19:08,543 INFO [jeeves.engine] - Initializing profiles...
2008-10-29 17:19:08,558 INFO [jeeves.engine] - Found handler :
org.fao.geonet.Geonetwork
2008-10-29 17:19:08,574 INFO [jeeves.engine] - --- Starting handler
2008-10-29 17:19:08,574 INFO [jeeves.apphand] - Initializing geonetwork...
2008-10-29 17:19:08,574 INFO [jeeves.apphand] - - Setting manager...
2008-10-29 17:19:08,621 INFO [jeeves.apphand] - - Thesaurus...
2008-10-29 17:19:08,668 DEBUG [geonetwork.thesaurus-man] - Adding thesaurus :
external.place.communesFR
2008-10-29 17:19:15,017 DEBUG [geonetwork.thesaurus-man] - Adding thesaurus :
external.place.DepartementFR
2008-10-29 17:19:15,049 DEBUG [geonetwork.thesaurus-man] - Adding thesaurus :
external.place.Pays
2008-10-29 17:19:15,127 DEBUG [geonetwork.thesaurus-man] - Adding thesaurus :
external.place.RegionFR
2008-10-29 17:19:15,142 DEBUG [geonetwork.thesaurus-man] - Adding thesaurus :
external.place.regions
2008-10-29 17:19:15,236 DEBUG [geonetwork.thesaurus-man] - Adding thesaurus :
external.theme.environnement
2008-10-29 17:19:15,251 DEBUG [geonetwork.thesaurus-man] - Adding thesaurus :
external.theme.inspire
2008-10-29 17:19:15,251 INFO [jeeves.apphand] - - Contact...
2008-10-29 17:19:15,267 INFO [jeeves.apphand] - - CRS...
2008-10-29 17:19:15,283 INFO [jeeves.apphand] - - Z39.50...
2008-10-29 17:19:15,283 INFO [jeeves.apphand] - Enabled. Schema
mappings is : schema-mappings.xml
2008-10-29 17:19:15,361 INFO [jeeves.apphand] - - Search...
2008-10-29 17:19:15,517 INFO [jeeves.apphand] - - Access manager...
2008-10-29 17:19:15,548 INFO [jeeves.apphand] - - Data manager...
2008-10-29 17:19:15,564 DEBUG [geonetwork.datamanager] - DB CONTENT:
'<response>
<record>
<id>1</id>
<changedate>2008-10-22T17:15:37</changedate>
</record>
<record>
<id>2</id>
</record>
<record>
<id>3</id>
</record>
<record>
<id>4</id>
</record>
<record>
<id>5</id>
</record>
<record>
<id>6</id>
</record>
<record>
<id>7</id>
</record>
<record>
<id>8</id>
</record>
<record>
<id>9</id>
<changedate>2007-01-26T10:42:16</changedate>
</record>
<record>
<id>10</id>
</record>
</response>'
2008-10-29 17:19:15,579 DEBUG [geonetwork.datamanager] - INDEX CONTENT:
2008-10-29 17:19:15,579 DEBUG [geonetwork.datamanager] - - record (1)
2008-10-29 17:19:15,579 DEBUG [geonetwork.datamanager] - Indexing record (1)
2008-10-29 17:19:15,610 DEBUG [geonetwork.datamanager] - record schema
(iso19110)
2008-10-29 17:19:15,610 DEBUG [geonetwork.datamanager] - record createDate
(2008-10-22T17:15:37)
2008-10-29 17:19:16,827 DEBUG [geonetwork.datamanager] - - record (2)
2008-10-29 17:19:16,827 DEBUG [geonetwork.datamanager] - Indexing record (2)
And stdout.log
exception while opening lucene index, going to rebuild it: no segments* file
found in
org.apache.lucene.store.FSDirectory@anonymised.com:\tmp\geonetwork\WEB-INF\lucene: files:
rebuilding lucene index
-----Message d'origine-----
De : Stephen.Davies@anonymised.com [mailto:Stephen.Davies@anonymised.com]
Envoyé : mercredi 29 octobre 2008 01:15
À : geonetwork-users@lists.sourceforge.net
Objet : Re: [GeoNetwork-users] Can't make Tomcat 5.5 and GeoNetwork
Hi Maël,
Not sure if this is the fix but try moving the deployed files to a directory
NOT under webapps e.g. "d:/geonetwork/220/web/geonetwork" and adjust the
docBase accordingly. Tomcat has a known bug
https://issues.apache.org/bugzilla/show_bug.cgi?id=39013 and I have had
problems deploying apps to this directory before.
Can't see why the IllegalArgumentException is being raised. If you search
Google with "javax.xml.validation.SchemaFactory tomcat
IllegalArgumentException" you'll find you're not the first to see this
problem.
I have been using Tomcat 5.5.26, Java 1.5.0_14 on Windows XP for 6 months
without encountering this problem.
Stephen
