AFAIK there's no plan to have such a functionality into GeoNetwork.
I think on the mailing list there are some people using pl/sql to do such an update. I've also made some php to do batch update ... but that's always quite a mess to set up that kind of update. Looping over all metadata and updating the xml parts ... If using that, take care of encoding to not to corrupt all xml files.
The use of an XML native db could be very very useful to do such jobs!
Cheers.
Francois
-----Message d'origine-----
De : geonetwork-users-bounces@lists.sourceforge.net [mailto:geonetwork-users-bounces@lists.sourceforge.net] De la part de Lukasz_Sobotowski
Envoyé : lundi 16 juillet 2007 13:08
À : geonetwork-users@lists.sourceforge.net
Objet : [GeoNetwork-users] how to modify many xml files at once ??
Hi,I have a question. If in GN it is possible to modify more then one file atonce?? When in database will be many metadata files (for example 10000) it will bedifficult to plot some changes to series. Then it is needed to modify forexample 700 metadata files. It will took a lot of time. Is it possible tomodify more then one xml file at once ?? If not do you plan to include thisin short time ??
Kind regards,Łukasz-- View this message in context: http://www.nabble.com/how-to-modify-many-xml-files-at-once----tf4085949s18419.html#a11613200Sent from the geonetwork-users mailing list archive at Nabble.com.
-------------------------------------------------------------------------This SF.net email is sponsored by DB2 ExpressDownload DB2 Express C - the FREE version of DB2 express and takecontrol of your XML. No limits. Just data. Click to get it now.http://sourceforge.net/powerbar/db2/_______________________________________________GeoNetwork-users mailing listGeoNetwork-users@...181...://lists.sourceforge.net/lists/listinfo/geonetwork-usersGeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork
