[GeoNetwork-devel] [GeoNetwork-users] PostGIS configuration in Geonetwork 3
I don’t really understand your issue.
postgres/postgis is the same data connexion. The 2 options provided by geonetwork are
  • postgres/postgis in direct connexion
  • postgres/postgis through JNDI
If you configured the first one then it’s ok, you configured your postgres/postgis DB with geonetwork.
You can add postgis extension if you want to, but it’s not needed for geonetwork. You could however use a postgis DB for your index, but it’s a different issue there.
The second one is through JDNI, it means you need to create a JNDI connexion resource somewhere in your Tomcat config to use it with geonetwork.
You should’nt need to touch neither jndi-postgres-postgis.xml nor postgres.xml files.
On Tue, May 26, 2015 at 5:57 PM, Òscar Chic <ochic@anonymised.com> wrote:
Do you mena this file:
jndi-postgres-postgis.xml ?
It’s is needed to configure to connect to Postgres/postGIS DB?
<beans default-lazy-init=“true”
xmlns=“http://www.springframework.org/schema/beans” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance”
xsi:schemaLocation="
http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans.xsd
Òscar
El 26/5/15 a les 17:05, Florent Gravin ha escrit:
Well, it’s JNDI, did you configure one ?
_______________________________________________________________________
Oscar Chic
Sotsdirector Tècnic
Institut de Ciències del Mar (ICM-CSIC)    Tel:   +34 932309529
Pg. Marítim de la Barceloneta, 37-49       Fax:   +34 932309555
08003 Barcelona, Spain                     email: [ochic@anonymised.com](mailto:ochic@anonymised.com..809...)
On Tue, May 26, 2015 at 5:02 PM, Òscar Chic <ochic@anonymised.com> wrote:
Thanks Florent!. It works.
But when I try to tune to postgresql_postGIS it doesn’t
Òscar
El 26/5/15 a les 14:53, Florent Gravin ha escrit:
Hi, i think you just need one database.
Either postgres (with postgis or not), either JNDI.
Try to use just the postgres config, remove your DB, create a new one, and see if the serveur startup fills the new DB with correct tables.
You’re then free to enable postgis extension in that base if you want to.
Oscar Chic
Sotsdirector Tècnic
Florent Gravin
Camptocamp - Chambéry
0479444492
On Tue, May 26, 2015 at 2:36 PM, Òscar Chic <ochic@anonymised.com> wrote:
I’m trying to configure a new Geonetwork 3 installed as a war file to
connect to postGIS
Before that I have a Geonetwork 2.10 running with this configuration
perfect:
main-db jeeves.resources.dbms.ApacheDBCPool geonetwork xxxxxx org.postgis.DriverWrapper
Then I update jdbc.properties (user, pass, host, db)
After that I create a clean PostGIS database with that parameters
Then reboot geonetwork but a lot of SEVERE errors related to datasource
Anybody knows the configuration of a GN 3 with PostGIS?
Thanks a lot
Òscar
Oscar Chic
Sotsdirector Tècnic
08003 Barcelona, Spain email: ochic@anonymised.com
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
GeoNetwork-users mailing list
Florent Gravin
0479444492
Florent Gravin
0479444492
I was struggling with connecting with PostGIS, and I found this thread very
helpful.
Just a follow up question, now I am able to connect GNK with Postgre, but I
want to use PostGIS for my index since I have a large volume of datasets. I
have already create postgis extension in postgre DB, but I don't think
PostGIS is being used (C:\Program
Files\geonetwork\web\geonetwork\WEB-INF\data\index), because the spatial
index file keep getting larger as I add data. Could you help me out with
this?
Thanks in advance,
Cody
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-GeoNetwork-users-PostGIS-configuration-in-Geonetwork-3-tp5207644p5208504.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
