[GeoNetwork-devel] [GeoNetwork-users] Problems with Dublin Core
Christian Gadge wrote:
Hello List,
I have to build a full functionally server version of GeoNetwork until end of december. We have plenty of data without a geographical content in our project, so I want to use the Dublin Core template to manage this kind of data. I read in the mailinglist that there will be a "fix release soon" (...14th october), that will rectify the problem with DC-template.
I am using eclipse including subclipse so I tried to build the application from SVN after running the build.xml from installer-folder [trunk]. The results seem to be correct, but after installing GN the DC template doesn't work as well.
this error appears...
The requested operation could not be performed.
IllegalArgumentException: Mismatch between schema and xml: No type for 'element': null with parent simpledc
Hi Christian,
Thanks for the prod :slight_smile: - it was me who promised the bug fix for this problem. The bug came about because of changes to support 19139 parsing we added and it has waited on more changes and testing in our working copy (which is a 2.0.3 version we're releasing as a metadata entry tool supporting 3 Australian profiles of 19115 in 19139 in the next few days).
Our mods to the schema parsing code look good for 19139 now but will probably need to be check people who know FGDC.
I will check FGDC to basic level (ie. it doesn't break) tomorrow (Thursday 13/12) and then commit these changes to the trunk so dc will live, thrive and survive again shortly with the 19139 fixes.
I think the release data is something that needs to be proposed and voted on in the developers group - this is just one fix and others will need to comment on what they want/need to do first.
Simon
