[GeoNetwork-devel] geonetwork WIS: SMTP - Unable to relay
If I've well understood, and in order to avoid the SMTP relay issues with the
mail servers of the organisation which hosts the WIS service, WIS
implementation should use some dedicated mail server, is'n it?
Does someone already did it? Would Apache-James be good solution in this
case?
Many thanks,
Victor
View this message in context: http://osgeo-org.1560.n6.nabble.com/geonetwork-WIS-SMTP-Unable-to-relay-tp4987378p4987637.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
I am not sure I understand the question. Could you maybe expand a bit.
On Wed, Jul 11, 2012 at 2:29 PM, vsinceac <victor.sinceac@anonymised.com> wrote:
If I’ve well understood, and in order to avoid the SMTP relay issues with the
implementation should use some dedicated mail server, is’n it?
case?
Many thanks,
Victor
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
WIS must send e-mails with meteo data to WIS users ; it uses java.mail to do this and the e-mails should be sent by SMTP using, in theory, the SMTP server of the organisation which hosts WIS. The problem is that each organisation has its own SMTP servers with many possibility for authorization protocols, etc… Usually, the SMTP raises an error “com.sun.mail.smtp.SMTPAddressFailedException: 550 5.7.1 Unable to relay” when WIS tries to send an e-mail from the SMTP server in the domain to an e-mail address in another domain (to avoid spamming). One solution would be to ask the SMTP admin to accept the relay requests coming from WIS, but not all admins would accept this… Another solution would be to use a dedicated mail server (it was my question in my second message). Does it make sense?
View this message in context: Re: geonetwork WIS: SMTP - Unable to relay
Huh, Wish I had some insight for you here. The SMTP servers have worked for the projects I have been on so far.
On Wed, Jul 11, 2012 at 2:46 PM, vsinceac <victor.sinceac@anonymised.com> wrote:
