Hello Heiki,
Thanks for your answer and advices.
In both cases you’d need to make some development effort I think.
Well, yes, that was predictable
Let us know how you are going to tackle your requirements?
We will, as soon as we know how to do it . We need to dive more into Geonetwork to figure out how to answer this issue exactly.
We may come back to the list for some others questions…
Xavier
De : heikki <tropicano@anonymised.com…>
A : xavier.merour@anonymised.com
Cc : geonetwork-devel@anonymised.comts.sourceforge.net
Date : 30.08.2011 16:03
Objet : Re: [GeoNetwork-devel] Geonetwork with multiple instances
hi Xavier,
for Lucene indexing, you could maybe request the service “metadata.admin.index.rebuild” on the instances where the index needs updating, but it triggers a complete re-index so that might not be so great if you have a lot of metadata.
for the database inserts, I don’t think there is a work-around
Another scenario might be that you actually keep different databases for each instance, and let them harvest each other. This would remove issues 1 and 2 but introduces issues of its own, such as how to sync user and group definitions, and you could run into a harvesting delete loop (see http://osgeo-org.1803224.n2.nabble.com/Harvesting-delete-logic-td4101665.html).
Kind regards
Heikki Doeleman
On Tue, Aug 30, 2011 at 3:25 PM, <xavier.merour@anonymised.com…780…> wrote:
Hello,
OK, thanks.
So next question
Is there any known workaround for issues 1 & 2 or the list (Lucene indexing & Database inserts) ?
We are only concerned by those two because we use GN as a CSW server (insert, fetch, edit and delete metadata). We do not use the GUI at all.
Regards
Xavier Mérour
De : heikki <tropicano@anonymised.com>
Cc : geonetwork-devel@lists.sourceforge.net
Date : 30.08.2011 15:07
Hi Xavier,
to my knowledge there is at present no project working on addressing these issues.
Cordialement
Heikki Doeleman
On Tue, Aug 30, 2011 at 2:56 PM, <xavier.merour@anonymised.com80…> wrote:
Hello,
As we plan to deploy Geonetwork on multiple instance (elastic cloud).
Could someone give any news on issues detailed here : http://trac.osgeo.org/geonetwork/wiki/MultipleInstancesOfGN
Is there any dev. or project in the pipe to move forward with this issue ?
Thanks to the list for any relevant information.
Xavier Mérour
Special Offer – Download ArcSight Logger for FREE!
Finally, a world-class log management solution at an even better
price-free! And you’ll get a free “Love Thy Logs” t-shirt when you
download Logger. Secure your free ArcSight Logger TODAY!
http://p.sf.net/sfu/arcsisghtdev2dev
GeoNetwork-devel mailing list
GeoNetwork-devel@anonymised.com.net
