I’m discovering more concurrency errors under load in geonetworks. BTW - thanks for CSW fix for error I reported earlier in week.
The errors are for geonetworks 2_4_1 in Tomcat 6.20 with 1000 iso records loaded:
- Massive Delete fails with java.util.ConcurrentModificationException - see stack trace below. This results in inconsistency between lucene index and database. Lucene index drops records up to point at which exception occurs. Since commit is never done in database, data still exists, and can be recovered by rebuilding lucene index.
- MassiveUpdatePriviledges fails with java.util.ConcurrentModificationException - see stack trace below
- MassiveUpdateCategories - got no stack trace recorded for this one.
Problem seems to be with HashSet declared in SelectionManager. These are wrapped as synchronizedSet, which requires all iterators to be in synchronized blocks (according to Java doc).
Iterators over this map in MassiveDelete / etc are not synchronized. Explicitly synchronizing the iterators when these sets are accessed seems to fix the concurrency problems:
eg
synchronized(sm.getSelection(“metadata”)) {
// use iterator here
Regards
James
Stack traces:
First the massive delete:
88562 [34658350@anonymised.com] ERROR jeeves.service - Exception when executing servic
e
788562 [34658350@anonymised.com] ERROR jeeves.service - (C) Exc : java.util.Concurrent
788562 [34658350@anonymised.com] DEBUG jeeves.service - Raised exception while executin
g service
en
metadata.massive.delete
Then the massive Privs:
1454281 [http-8080-3] ERROR jeeves.service - Exception when executing service
1454281 [http-8080-3] ERROR jeeves.service - (C) Exc : java.util.ConcurrentMod
ificationException
at java.util.HashMap$HashIterator.nextEntry(HashMap.java:921)
at java.util.HashMap$KeyIterator.next(HashMap.java:956)
at org.fao.geonet.services.metadata.MassiveUpdatePrivileges.exec(Massive
UpdatePrivileges.java:85)
at jeeves.server.dispatchers.ServiceInfo.execService(ServiceInfo.java:24
4)
at jeeves.server.dispatchers.ServiceInfo.execServices(ServiceInfo.java:1
41)
at jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java
:377)
at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:621)
at jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:1
74)
at jeeves.server.sources.http.JeevesServlet.doGet(JeevesServlet.java:89)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Appl
icationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationF
ilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperV
alve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextV
alve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.j
ava:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.j
ava:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineVal
ve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.jav
a:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java
:849)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.proce
ss(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:45
4)
at java.lang.Thread.run(Thread.java:619)
Thanks James - see ticket 161 - same problem would have turned up in a few other places too!
Simon
James Wilson wrote:
I'm discovering more concurrency errors under load in geonetworks. BTW - thanks for CSW fix for error I reported earlier in week.
eg
synchronized(sm.getSelection("metadata")) {
Regards
James
Stack traces:
e
g service
<error id="error">
<message />
<class>ConcurrentModificationException</class>
<stack>
<at class="java.util.HashMap$HashIterator" file="HashMap.java" line="921" me
thod="nextEntry" />
<at class="java.util.HashMap$KeyIterator" file="HashMap.java" line="956" met
hod="next" />
<at class="org.fao.geonet.services.metadata.MassiveDelete" file="MassiveDele
te.java" line="87" method="exec" />
<at class="jeeves.server.dispatchers.ServiceInfo" file="ServiceInfo.java" li
ne="238" method="execService" />
ne="141" method="execServices" />
<at class="jeeves.server.dispatchers.ServiceManager" file="ServiceManager.ja
va" line="377" method="dispatch" />
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java" line="621" m
ethod="dispatch" />
<at class="jeeves.server.sources.http.JeevesServlet" file="JeevesServlet.jav
a" line="174" method="execute" />
a" line="89" method="doGet" />
<at class="javax.servlet.http.HttpServlet" file="HttpServlet.java" line="707
" method="service" />
</stack>
<request>
<language>en</language>
<service>metadata.massive.delete</service>
</request>
</error>
ificationException
4)
41)
:377)
74)
alve.java:233)
alve.java:191)
ava:128)
ava:102)
ve.java:109)
a:293)
:849)
4)
Come build with us! The BlackBerry(R) Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay ahead of the curve. Join us from November 9 - 12, 2009. Register now!
Best Open Source Mac Front-Ends 2024
GeoNetwork-devel mailing list
geonetwork-devel List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
