[GeoNetwork-devel] GeoNetwork's status and 2.1 Beta
I have committed a lot of code. What you have now in SVN is a beta
version. Here are the main news:
- finished localization form
- finished MEF import/export facilities
- added backup/restore facility in GAST using MEF
- updated the PDF manual
What is missing is only the code to upgrade GN 2.0.3 to 2.1.
The code is inside GAST but it does not work now.
Probably, we will release an installer shortly. Any feedback is welcome.
A note about localization. For regions, categories, operations and groups
there is only the english version for all available languages. You can use
the localization form to localize these strings in your language and then
export the table's content using druid. If you send us the localized strings
we can add them to the project.
Hi all, hi Andrea and Yeroen
Andrea mentioned “added backup/restore facility in GAST” and CS/W support.
What transfer file format would you suggest to be implemented in another software in order to share datasets with GeoNetwork (exact spec./xsd’s)?
Are these structures also supported in CS/W as well as in future OAI-PMH?
– Stefan
2007/2/12, Andrea Carboni <acarboni@anonymised.com>:
  • finished localization form
  • finished MEF import/export facilities
  • added backup/restore facility in GAST using MEF
  • updated the PDF manual
export the table’s content using druid. If you send us the localized strings
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier.
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
GeoNetwork-devel mailing list
Hi Stefan,
into docs/manuals you can find the spec of the GeoNetwork's metadata
exchange format (MEF). That format can be used to backup/restore
metadata and to share it as well. Each metadata is exported into a MEF
file with all information about privileges, categories, groups etc... That
file can be imported into another geonetwork node.
CS/W and OAI-PMH are protocols designed for different purposes. If you
want to share geonetwork's metadata, the MEF format is recommended.
Andrea mentioned "added backup/restore facility in GAST" and CS/W support.
software in order to share datasets with GeoNetwork (exact spec./xsd's)?
-- Stefan
> Hi all,
> strings
> Cheers,
> Andrea
> easier.
