[GeoNetwork-devel] GeoRSS does not validate
I have been making some local changes to the RSS feed, as it doesn’t validate for me as is. I used this validator available under the firefox tools menu.
http://validator.w3.org/feed/
Main items that caused the failure.
  • Multiple sub-elements in the element. Fixed by removed distribution online links.
  • The date format used for the element, needs to be RFC822. Fixed by adding new element to info generator for metadata record.
  • The use of the media:content and media:text elements. Just commented these out.
  • Removed the xml comments.
  • For the thumbnail hrefs, needed to have full path to thumbnail.
Maybe it doesn’t matter that the validation fails, or it’s the validator that I’m using that’s the issue. Just thought I’d put this out there for some comments and feedback.
Kevin Gunn
Australian Institute of Marine Science
http://data.aims.gov.au/geonetwork/srv/en/main.home
The information contained within this transmission is for the
use of the intended recipient only and may contain confidential
and/or legally privileged material and/or material the subject
of copyright and/or personal information and/or sensitive
information that is subject to the Privacy Act 1988. Any review,
re-transmission, disclosure, dissemination or other use of, or
taking of any action in reliance upon, this information by
persons or entities other than the intended recipient is
prohibited. If you have received this email in error please
notify the AIMS Privacy Officer on (07) 4753 4444 and delete
all copies of this transmission together with any attachments.
