My server fails intermittently with a stack trace as follows:
javax.xml.transform.TransformerConfigurationException: Could not compile stylesheet
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerFactoryImpl.newTemplates(TransformerFactoryImpl.java:825)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerFactoryImpl.newTransformer(TransformerFactoryImpl.java:614)
at jeeves.utils.Xml.transform(Xml.java:237)
at jeeves.utils.Xml.transform(Xml.java:181)
at org.fao.geonet.guiservices.util.Env.exec(Env.java:57)
You may note that the transformer is now Xalan, where it was Saxon.
I have found this note:
http://osgeo-org.1803224.n2.nabble.com/TransformerFactory-problem-with-GN-2-4-2-and-Tomcat-6-0-18-td4519136.html
It suggests that the problem is bad behaviour by Geoserver, and can be fixed by installing Geonetwork and Geoserver into two different containers.
Does anyone have any further information that could confirm that my diagnosis is correct (or not).
Justin.
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
hi Justin,
this is quite possible. See trac ticket http://trac.osgeo.org/geonetwork/ticket/387
I’ve made a fix to go in trunk and 2.6.x, likely. If so, it should be solved from 2.6.2.
Kind regards
Heikki Doeleman
On Fri, Dec 3, 2010 at 1:08 PM, Justin Rowles (C) <Justin.Rowles@anonymised.com> wrote:
Justin.
Ordnance Survey
Romsey Road
Tel: 08456 050505
[http://www.ordnancesurvey.co.uk](http://www.ordnancesurvey.co.uk)
Increase Visibility of Your 3D Game App & Earn a Chance To Win $500!
Tap into the largest installed PC base & get more eyes on your game by
optimizing for Intel(R) Graphics Technology. Get started today with the
Intel(R) Software Partner Program. Five $500 cash prizes are up for grabs.
http://p.sf.net/sfu/intelisp-dev2dev
GeoNetwork-devel mailing list
