[GeoNetwork-devel] GeoServer submodule
Hi
I have updated 3.0.x branch to point to the correct revision having the pom version 3.0.1-SNAPSHOT (previously, the revision pointed had 2.11 version)
But noticed that both 3.0.x and develop branches of Geonetwork use the the same submodule branch (master). I think we need to create a 3.0.x branch also for this submodule, otherwise when releasing new releases of 3.0.x is going to be a bit messy.
Any opinion about this? If looks fine, I’ll check to create the branch
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hola Jose
2015-07-01 13:55 GMT+02:00 Jose Garcia <jose.garcia@anonymised.com7…>:
Hi
+1 for me even if should probably at some point drop the submodule and simply download the WAR for building the installer version (we are not using the WMS anymore for background maps so we could save space here) ?
Cheers.
Francois
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Don’t Limit Your Business. Reach for the Cloud.
GigeNET’s Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today.
https://www.gigenetcloud.com/
GeoNetwork-devel mailing list
Hi
Then, GeoServer is not used anymore? Or the GeoPublisher uses it?
If not, not really sure that makes much sense even to include it in the installer.
Jose García
On Wed, Jul 1, 2015 at 3:25 PM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Hola Jose
2015-07-01 13:55 GMT+02:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi
Cheers.
Francois
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
2015-07-01 15:36 GMT+02:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi
It may be used if you configure it, but you can use an existing one (or
even MapServer).
installer.
We discussed that in Bolsena, and the conclusion was that's also good to
have a simple package with both GeoNetwork and GeoServer (even if it's
quite simple to install geoserver.war once you have GeoNetwork running). It
would make the repository easier to maintain, if we just remove it.
Francois
Jose García
wrote:
Hola Jose
Hi
version)
Any opinion about this? If looks fine, I'll check to create the branch
Cheers.
Francois
Jose García
*GeoCat Bridge for ArcGIS allows instant publishing of data and metadata
<http://geocat.net/&gt; for details. _________________________Jose
GarcíaGeoCat bvVeenderweg 136721 WD BennekomThe
Netherlandshttp://GeoCat.net/>*
Don't Limit Your Business. Reach for the Cloud.
GigeNET's Cloud Solutions provide you with the tools and support that
