[GeoNetwork-devel] GeoServer version update
Hi developers,
The currently shipped version of GeoServer in GeoNetwork is outdated. The pom.xml says it is version 2.1.1 (which is really old by now). Is there a good reason NOT to upgrade to the latest version 2.4.2 in our automated build scripts?
Jeroen
Hi
The main issue for me was that I have no clear the procedure to update the geoserver. GeoServer is stored in the maven_repo module as a maven artifact and requires some additional stuff of maven files, not just put the new geoserver.war.
Most probably is due to my ignorance about how to manage this, but anyway would be nice to have some documentation about the maven_repo project, related to add new artifacts or update the maven artifacts in that module.
Jose García
On Fri, Nov 29, 2013 at 8:16 AM, Jeroen Ticheler <jeroen.ticheler@anonymised.com> wrote:
Hi developers,
Jeroen
Rapidly troubleshoot problems before they affect your business. Most IT
organizations don’t have a clear picture of how application performance
affects their revenue. With AppDynamics, you get 100% visibility into your
Java,.NET, & PHP application. Start your 15-day FREE TRIAL of AppDynamics Pro!
http://pubads.g.doubleclick.net/gampad/clk?id=84349351&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
I believe that we could use the opengeo maven repository to resolve the geoserver artifacts instead of the ones in maven_repo. I don’t see an real reason for keeping the geoserver files in the repo except in the case that the opengeo repo goes away. Until that time we can probably use the artifacts in the opengeo repo.
It will take some time to evaluate what effect that will have though. The build might have to be changed slightly.
Jesse
On Fri, Nov 29, 2013 at 8:51 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi
Jose García
Hi developers,
Jeroen
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi Jesse
I have take a quick look to http://repo.opengeo.org/ and I think if we use it we’ll need to build the geoserver war file (at least didn’t find an artifact for it).
I guess actual approach with maven_repo should be fine, the only stuff for me is the lack of documentation about how to manage updates or new artifacts. I’m checking some documentation about this and want to manage some tests.
In some moment would be nice to check about having an online repository for GeoNetwork and all the dependencies, so no need of the maven_repo.
Jose García
On Fri, Nov 29, 2013 at 9:24 AM, Jesse Eichar <jesse.eichar@anonymised.com> wrote:
Jesse
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
On Fri, Nov 29, 2013 at 8:51 AM, Jose Garcia <jose.garcia@anonymised.com…> wrote:
Hi
Jose García
Hi developers,
Jeroen
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
I have done it for several projects and it is not difficult. However I do not have time so go ahead and do the normal update and we can migrate in the future.
On Fri, Nov 29, 2013 at 9:32 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Jesse
Jose García
Jesse
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi
Jose García
Hi developers,
Jeroen
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi
The version of GeoServer is updated to version 2.4.2 in develop branch. Not sure if want also to upgrade the version for 2.10 branch?
I added in https://github.com/geonetwork/core-geoserver the steps to upgrade to newer versions of GeoServer, so are more clear the steps.
Jose García
On Fri, Nov 29, 2013 at 10:28 AM, Jesse Eichar <jesse.eichar@anonymised.com> wrote:
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi Jesse
Jose García
On Fri, Nov 29, 2013 at 9:24 AM, Jesse Eichar <jesse.eichar@anonymised.com…> wrote:
Jesse
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi
Jose García
Hi developers,
Jeroen
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Thanks a lot Jose, that’s great!
Jeroen
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi Jesse
Jose García
Jesse
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi
Jose García
Hi developers,
Jeroen
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
On Fri, Nov 29, 2013 at 11:57 AM, Jeroen Ticheler <
Thanks a lot Jose, that's great!
can I share 2 cents about this topic?
I see form Jose instructions that you're building a GeoServer with some
extensions, a custom one, if you will.
We do this all the time, and the "suggested" way to do so is to:
* take the web/app contents, which are really just little more than a
web.xml and a pom file (there is no java)
* make it your own module, customize the pom file to drop whatever you
don't need, and add whatever you
  need instead
* build this new module, it will generate a GeoServer that satisfy your
needs, and should work off the existing repos without
  a need to deploy manually war files and the like
Hope this helps
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea
Thanks a lot for sharing this information. I’ll check next week to update with your proposal, I guess should work better to improve the upgrades to use the latest stable version of GeoServer.
Jose García
On Fri, Nov 29, 2013 at 12:20 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
On Fri, Nov 29, 2013 at 11:57 AM, Jeroen Ticheler <jeroen.ticheler@anonymised.com> wrote:
I see form Jose instructions that you’re building a GeoServer with some extensions, a custom one, if you will.
We do this all the time, and the “suggested” way to do so is to:
  • take the web/app contents, which are really just little more than a web.xml and a pom file (there is no java)
  • make it your own module, customize the pom file to drop whatever you don’t need, and add whatever you
    need instead
  • build this new module, it will generate a GeoServer that satisfy your needs, and should work off the existing repos without
Hope this helps
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Nov 29, 2013 at 12:40 PM, Jose Garcia <jose.garcia@anonymised.com>wrote:
Hi Andrea
Thanks a lot for sharing this information. I'll check next week to update
Well, yes, in theory, you should be able to update the GeoServer by just
changing the version number in the pom file of that
module (which can be centralized in a property).
It has it own downsides though, the build gets slower because it has to
assemble the .war from the various jars available
in the maven repo.
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea
I guess should be not a big issue, as we need to build geoserver module only when creating the installer. For development no need to build it.
Jose García
On Fri, Nov 29, 2013 at 12:43 PM, Andrea Aime <andrea.aime@anonymised.com924…> wrote:
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
On Fri, Nov 29, 2013 at 12:40 PM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Andrea
Well, yes, in theory, you should be able to update the GeoServer by just changing the version number in the pom file of that
It has it own downsides though, the build gets slower because it has to assemble the .war from the various jars available
in the maven repo.
Ing. Andrea Aime
@geowolf
Technical Lead
