[GeoNetwork-devel] GeoServer.
For the record, I solved the installer/build.xml issue as follows:
It was failing when used inside Cygwin. It works fine under Windows shell (cmd.exe).
It works fine in Cygwin if I export the USERPROFILE environment variable with the win16 version (c:\Docume~1\justin instead of c:\Documents and Settings\justin). Easy!
Now to get back to trying to install into my Unix server so that GeoServer deploys J
Justin.
Sent: 30 July 2010 15:08
To: geonetwork-devel@lists.sourceforge.net
Subject: GeoServer.
All,
Just in case I am trying to solve a known problem:
I am trying to deploy geonetwork (and geoserver) to an Apache/Tomcat/Mysql/Linux server. I can take the GeoNetwork.war from /web/target and deploy that, but the geoserver.war from geoserver/target fails to deploy.
Thus I get a GeoNetwork install without pretty map bits on the front page.
Is this something anyone is working on? Am I doing something that is not supported? Am I required to use the Unix install functions? At present the installer/build.xml fails for me.
Justin.
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
