I am developing a Java application that is interacting with Geonetwork
server via REST.
I would like to list all available metadata records in a specific view
of my application;
for each metadata to be listed I have to show its Title and id.
My issue is that I would like to get Title and ID of all metadata
records with a single REST call.
I know how to make a search via REST, but the response record does not
contain the
titles of metadata records.
Do you know if there is some way to get ALL metadata titles with a
single REST call?
I am trying to avoid as much as possible to get all full metadata
records just for getting their titles...
Best regards and thanks for your help,
Ivano
Ivano Malavolta
PhD Student in Computer Science
tel: +390862433734 skype: iivanoo
University of L'Aquila
Department of Computer Science
Via Vetoio - 67010 (AQ) - Italy
Did you ever find a solution to this? I am currently using a xml.metadata.get
call for each record returned in a template search to do essentially the
same thing. (Mine goes to a hashmap which populates a select list from which
a user can sellect a template by name and retrieve that template record.)
But I find I need to parse the returned info separately for each metadata
standard used. The geonet:info section (which is turned off by default in
6.3) looked promising for this because it has a tag for "title", but
unfortunately, this tag seems to always be empty.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/get-all-metadata-titles-with-a-single-REST-call-tp5846016p6585055.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
I found a solution to this. Instead of using xml.metadata.get I use csw. That
brings the records back in a consistent format with uuids and title. (Dublin
core)
View this message in context: http://osgeo-org.1803224.n2.nabble.com/get-all-metadata-titles-with-a-single-REST-call-tp5846016p6585498.html
