[GeoNetwork-devel] getHandlerContext Problem
Hi list,
I’am developing on Geonework with Eclipse+Tomcat. When I deploy Geonetwork and try to login, a NullPointer Exception appears in this line of exec method in Login.java:
public Element exec(Element params, ServiceContext context) throws Exception
String username = Util.getParam(params, Params.USERNAME);
String password = Util.getParam(params, Params.PASSWORD);
GeonetContext gc = (GeonetContext) context.getHandlerContext(Geonet.CONTEXT_NAME);
SettingManager sm = gc.getSettingManager();
Dbms dbms = (Dbms) context.getResourceManager().open(Geonet.Res.MAIN_DB);
The problem is that getHandleContext method return null.
Any idea about the reason of this fail?
Thanks in advance…
Hello Francisco:
I found very usefull this guide: http://lab.usgin.org/sites/default/files/application/file/u5/GeoNetworkEclipseSetup_0.pdf
Hola Francisco:
Esta guía fue muy útil, muestra la configuración para Eclipse+Tomcat sobre WinXP.
Un saludo
2010/7/6 Francisco <ricken11@anonymised.com>
Hi list,
Thanks in advance…
This SF.net email is sponsored by Sprint
What will you do first with EVO, the first 4G phone?
Visit sprint.com/firsthttp://p.sf.net/sfu/sprint-com-first
GeoNetwork-devel mailing list
Enrique Jesús Cardona Cebrián
Hello Francisco again:
I can reproduce your problem shutting down my database. When DB is up and running there aren’t any probs.
Francisco, hola de nuevo:
Puede reproducir tu problema desactivando la base de datos. Pero cuando volví a activarla puede usar el servicio de Login correctamente.
Espero haber sido de ayuda.
Hi list,
Thanks in advance…
