[GeoNetwork-devel] git submodules - firwall issue
I'm having some issues with cloning geonetwork submodules due to firewall
issues.
The port which "git" protocol uses (9418) is blocked by our firewall
policies. So, when I try to do a clone to the project I use the "https"
protocol instead of the "GIT" protocol. (git clone --recursive
https://github.com/geonetwork/core-geonetwork.git), but I can't receive the
files in from submodule, as they use the git protocol, so I receive a broken
clone.
I would like to suggestion that you use https for the .gitsubmodule file.
From what I can tell the submodule aren't that big, so the git protocol
(which is faster) is probably not really required, and it would avoid a lot
of problems for other users.
For now, as a workaround, I'm was able to to edit the .gitsubmodules
(changing all the "git://" to "https://") and do a "git submodule sync". I
had a few issues updating the submodules afterwords but finally got it
working. This is kind of a nuisance that I would not like to have to repeat
each time I create a clone.
Any chance on changing this?
Thanks.
View this message in context: http://osgeo-org.1560.n6.nabble.com/git-submodules-firwall-issue-tp4991065.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
An excellent point. i will update the submodules for master, 2.8 and 2.6 right now
Jesse
On Thu, Jul 26, 2012 at 3:50 PM, ianwallen <ianwallen@anonymised.com> wrote:
I’m having some issues with cloning geonetwork submodules due to firewall
issues.
The port which “git” protocol uses (9418) is blocked by our firewall
policies. So, when I try to do a clone to the project I use the “https”
protocol instead of the “GIT” protocol. (git clone --recursive
https://github.com/geonetwork/core-geonetwork.git), but I can’t receive the
clone.
From what I can tell the submodule aren’t that big, so the git protocol
For now, as a workaround, I’m was able to to edit the .gitsubmodules
(changing all the “git://” to “https://”) and do a “git submodule sync”. I
Thanks.
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
