[GeoNetwork-devel] gmd:dateStamp/gco:DateTime
Hi List,
I’m doing testing on GeoNetwork trunk 2.7 (rev 8059), tested creating a few metadata and trying to list the records in RIF-CS format :
http://localhost:8080/geonetwork/srv/en/oaipmh?verb=ListRecords&metadataPrefix=rif
The above URL will return all records but when filter base on date :
http://localhost:8080/geonetwork/srv/en/oaipmh?verb=ListRecords&metadataPrefix=rif&from=2000-01-20T13:00:15&until=2011-08-18T00:00:00
The records that the gco:DateTime that is null as below will not be returned.
gmd:dateStamp
<gco:DateTime />
</gmd:dateStamp>
Since creating metadata record base on template will actually copied the gco:DateTime base on the original template, and from the GeoNetwork GUI page, user are not able to edit that date, so, my question would be:
  1. Why the following filter require value in gmd:dateStamp/gco:DateTime when I set the OAI Provider datesearch to modification date in Admin->System Configuration setting ?
  2. From the GeoNetwork GUI page, when mouse over the Date Stamp, the explaination : “Date that the metadata was created (YYYY-MM-DDThh:mm:ss) mandatory”, so why not when the metadata is created base on the template, the created date time be set to gmd:dateStamp/gco:DateTime ?
Any help or pointer would be very much appreciated.
Thanks & Regards,
Florence Tan
Software Engineer | Auscope Grid
CSIRO Earth Science and Resource Engineering
Phone: +61 8 6436 8802 | Fax: +61 8 6436 8559
florence.tan@anonymised.com | www.csiro.au
Address: Australian Resources Research Centre, 26 Dick Perry Avenue, Kensington WA 6151
PLEASE NOTE
The information contained in this email may be confidential or privileged. Any unauthorised use or disclosure is prohibited. If you have received this email in error, please delete it immediately and notify the sender by return email. Thank you. To the extent permitted by law, CSIRO does not represent, warrant and/or guarantee that the integrity of this communication has been maintained or that the communication is free of errors, virus, interception or interference.
Please consider the environment before printing this email.
