I’ve been looking at gmx:Anchor which is currently not supported (update-fixed-info.xsl):
Is anyone out there working on supporting it before I go any further? I don’t want to duplicate effort?
Just.
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Adanac Drive
Southampton SO16 0AS
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
Hello Justin,
2011/10/17 Justin Rowles (C) <Justin.Rowles@anonymised.com>:
I've been looking at gmx:Anchor which is currently not supported
<!-- Replace gmx:Anchor element by a simple gco:CharacterString.
gmx:Anchor is usually used for linking element using xlink.
TODO : Currently gmx:Anchor is not supported
don't want to duplicate effort?
Not from my side.
gmx:Anchor are supposed to point to HTML pages, XML fragments ?
The main issue I see adding this, is that the XLink resolver, if
actived, will try to resolve the link and insert it into the document
so maybe you'll have to bypass that if this is not required.
Cheers.
Francois
Just.
Ordnance Survey
Adanac Drive
Tel: 08456 050505
All the data continuously generated in your IT infrastructure contains a
definitive record of customers, application performance, security
threats, fraudulent activity and more. Splunk takes this data and makes
sense of it. Business sense. IT sense. Common sense.
http://p.sf.net/sfu/splunk-d2d-oct
GeoNetwork-devel mailing list
We are usually using gmx:Anchor to point to external resources, thesaurus for example.
gmd:MD_Keywords
gmd:keyword
<gmx:Anchor xlink:href=“http://www.eionet.europa.eu/gemet/concept/3650”>Geology</gmx:Anchor>
</gmd:keyword>
Frédéric
2011/10/20 Francois Prunayre <fx.prunayre@anonymised.com>
Hello Justin,
Not from my side.
so maybe you’ll have to bypass that if this is not required.
Cheers.
Francois
Just.
any contract be formed on Ordnance Survey’s behalf via email. We reserve the
Ordnance Survey
Adanac Drive
Tel: 08456 050505
The demand for IT networking professionals continues to grow, and the
demand for specialized networking skills is growing even more rapidly.
Take a complimentary Learning@anonymised.com Self-Assessment and learn
about Cisco certifications, training, and career opportunities.
http://p.sf.net/sfu/cisco-dev2dev
Hello Frédéric,
Le 20 octobre 2011 12:13, Frédéric Houbie <frederic@anonymised.com> a écrit :
for example.
<gmd:MD_Keywords>
<gmd:keyword>
<gmx:Anchor xlink:href="http://www.eionet.europa.eu/gemet/concept/3650">Geology</gmx:Anchor>
</gmd:keyword>
Did you made changes to GeoNetwork to support that ?
You should try to active the XLink (from the admin) and see what happens then !
Cheers.
Francois
Frédéric
Hello Justin,
> Hi all,
Not from my side.
Cheers.
Francois
> Just.
> may
> error,
> can
> the
> Ordnance Survey
> Adanac Drive
> Tel: 08456 050505
Hi François,
I was just talking about the usage we make of the gmx:Anchor in ISO19115/39 in our projects. I’m not using Geonetwork for cataloguing.
Frédéric
Le 20 octobre 2011 12:59, Francois Prunayre <fx.prunayre@anonymised.com> a écrit :
Hello Frédéric,
for example.
gmd:MD_Keywords
gmd:keyword
</gmd:keyword>
Cheers.
Francois
Frédéric
Hello Justin,
Not from my side.
Cheers.
Francois
Just.
may
error,
can
the
Ordnance Survey
Adanac Drive
Tel: 08456 050505
Hello Justin, I've a draft patch available here
http://trac.osgeo.org/geonetwork/ticket/681
which works for trunk and the Widgets UI.
Comments & tests welcomed.
Cheers.
Francois
Just.
Ordnance Survey
Adanac Drive
Tel: 08456 050505
