Hello Andrea,
I don't still receive any error message when I use the GAST in a Windows
console. It doesn't matter; I used the XML import service for importing
manually my storage. It was relatively quickly.
I have another question... now I want to export my metadata/data. When I use
the Export, the GAST produces many warnings:
17828 [Thread-46] WARN org.apache.commons.httpclient.cookie.CookieSpec -
Invalid cookie state: domain not specified
I don't know if this is really important, the question is that when I import
this set of exported data/metadata to a new clean Geonetwork 2.1
Installation, the GAST doesn't import anything and it outputs the following
error message: "File not found in info.xml : public"
The console error stack trace is the following:
2007-05-03 19:23:10,413 INFO [jeeves.request] -
2007-05-03 19:23:10,413 INFO [jeeves.request] - HTML Request (from
127.0.0.1) :
/geonetwork/srv/en/xml.user.login
2007-05-03 19:23:10,413 INFO [jeeves.service] - Dispatching :
xml.user.login
2007-05-03 19:23:10,413 INFO [jeeves.webapp.xml.user.login] - User 'admin'
logged in.
2007-05-03 19:23:10,413 INFO [jeeves.service] - -> dispatching to output
for : xml.user.login
2007-05-03 19:23:10,413 INFO [jeeves.service] - -> writing xml for :
xml.user.login
2007-05-03 19:23:10,413 INFO [jeeves.service] - -> output ended for :
xml.user.login
2007-05-03 19:23:10,413 INFO [jeeves.service] - -> dispatch ended for :
xml.user.login
2007-05-03 19:23:10,429 INFO [jeeves.request] -
2007-05-03 19:23:10,429 INFO [jeeves.request] - HTML Request (from
127.0.0.1) : /geonetwork/srv/en/mef.import
2007-05-03 19:23:10,429 INFO [jeeves.service] - Dispatching : mef.import
2007-05-03 19:23:11,179 ERROR [jeeves.service] - Exception when executing
service
2007-05-03 19:23:11,179 ERROR [jeeves.service] - (C) Exc :
java.lang.Exception:
Do you have any idea about this?
Best Regards,
Angel
-----Mensaje original-----
De: geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] En nombre de Andrea
Carboni
Enviado el: viernes, 20 de abril de 2007 17:57
Para: geonetwork-devel@lists.sourceforge.net
Asunto: Re: [GeoNetwork-devel] GN 2.1.0 beta1 Migration data process
Hi Angel,
try to run GAST using a Windows console you should see at least an
error message. Meanwhile, I'm trying to improve GAST's logging.
Hello Andrea,
I don't have any kind of data migrated. I've used Druid client to see DB
structure of GN 2.1 after the migration process and the tables remain
without any change.
Is there any log file where I can see the trace of the migration process?
I think that one problem I am having is that the GAST tool doesn't show me
any error message and neither does the Jetty console.
Angel
Carboni
Enviado el: miércoles, 18 de abril de 2007 13:05
Hi Angel,
do you have users, groups, categories etc migrated?
Regarding metadata, GAST does not migrate records whose source
is different than the siteId of your installation. Those metadata are
considered harvested and are skipped.
> Hello Andrea,
> Thank you for your prompt answer. Yes, I did it this way as it is
described
> in the [GEONETWORK_HOME]\docs\manuals\user-guide.pdf about using of GAST
> tool. The two servers are stopped but the migration process did still
not
> produce any migration result. I click on "Migrate", then a "Migrating
data"
> message appears with 0% during a few seconds, and suddenly the process
ends,
> but anything is migrated in the new geonetwork when I restart it. Any
idea
> else?
> Best Regards,
> Angel
> Carboni
> Enviado el: martes, 17 de abril de 2007 16:37
> Hi Angel,
> when you use GAST to migrate an old installation both the old one
> and the new one must be stopped (as GAST suggests with a stop icon).
> You get errors because GAST is trying to start the old mckoi database
> but the old one is still up and running so a conflict occurs.
> Cheers,
> Andrea
> > Dear all,
> > Weve recently installed Geonetwork 2.1 Server beta version. We have a
> > platform with a big amount of data and metadata in our Geonetwork
2.0.2
> > Desktop release version. Does anyone know how is the exact process to
> > migrate the whole data and thumbnail model from this previous version
to
> the
> > new version of Geonetwork?
> > We have tried to do this with the GAST tool by the Migration option
but
it
> > seems it doesnt work. First, the tool provides an address already in
> use
> > error, and when we fix it changing the DBMS port from 9157 to another
like
> > 9200, the tool doesnt provide any error message but the migration
process
> > doesnt produce any result; there is no new data migrated in the
> Geonetwork
> > 2.1.
> > Could anyone provide us support on this? Thanks in advance.
> > Best Regards,
> > Angel
> > Angel ZABALLOS
> > Project Engineer
> > GTD SISTEMAS DE INFORMACIÓN
> > Pg. Garcia Fària, 17 E-08005 Barcelona
> > Tel.: +34 934 939 300 Fax: +34 934 939 302
> > www.gtd.es - angel.zaballos@anonymised.com
> > Este mensaje es confidencial. Cualquier distribución, uso o copia del
> > mensaje o de la información en el contenido por otras personas
distintas
> de
> > los destinatarios esta prohibida. Si usted recibe este mensaje por
error,
> > por favor comuníquemelo inmediatamente mediante reenvío del mensaje o
por
> > otro medio.
> > This e-mail may be confidential. Any distribution, use or copying of
this
> > e-mail or the information it contains by other than an intended
recipient
> is
> > unauthorized. If you received this e-mail in error, please advise me
(by
> > return e-mail or otherwise) immediately.
> > Ce courriel est confidentiel. Toute diffusion, utilisation ou copie de
ce
> > message ou des renseignements qu'il contient par une personne autre
que
> les
> > destinataires désignés est interdite. Si vous recevez ce courriel par
> > erreur, veuillez m'en aviser immédiatement, par retour de courriel ou
par
> un
> > autre moyen.
> This SF.net email is sponsored by DB2 Express
> Download DB2 Express C - the FREE version of DB2 express and take
> control of your XML. No limits. Just data. Click to get it now.
> http://sourceforge.net/powerbar/db2/
> GeoNetwork-devel mailing list
> GeoNetwork-devel@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geonetwork-devel
> GeoNetwork OpenSource is maintained at
> http://sourceforge.net/projects/geonetwork
