[GeoNetwork-devel] [GN 2.10 RC0,1] XML Services seem not working
Dear developers,
I have upgraded my GeoNetwork from 2.8 to 2.10 where I am using its XML services in order to implement some steps in my workflow, namely Login, Harvesting, etc, services.
After my upgrade I experienced the following problem while using those services. For example the POST request:
<?xml version="1.0" encoding="UTF-8"?> admin admin
To URL: http://localhost:8080/geonetwork/srv/eng/xml.user.login
brings back the following error message from geonetwork:
Error 500 org.apache.jsp.login_jsp
HTTP ERROR 500
Problem accessing /geonetwork/login.jsp. Reason:
Caused by:
java.lang.ClassNotFoundException: org.apache.jsp.login_jsp
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at org.apache.jasper.servlet.JasperLoader.findClass(JasperLoader.java:204)
at org.apache.jasper.servlet.JasperLoader.loadClass(JasperLoader.java:190)
at org.apache.jasper.servlet.JasperLoader.loadClass(JasperLoader.java:122)
at org.apache.jasper.JspCompilationContext.load(JspCompilationContext.java:639)
at org.apache.jasper.servlet.JspServletWrapper.getServlet(JspServletWrapper.java:192)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:372)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:486)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:380)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:534)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1352)
at org.fao.geonet.monitor.webapp.WebappMetricsFilter.doFilter(WebappMetricsFilter.java:96)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1323)
at org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter.doFilter(MetricsRegistryInitializerFilter.java:31)
at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:381)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:178)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:155)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:237)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:167)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:474)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:119)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:480)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:934)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:404)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:184)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:869)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:247)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:151)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
at org.eclipse.jetty.server.Server.handle(Server.java:346)
at org.eclipse.jetty.server.HttpConnection.handleRequest(HttpConnection.java:581)
at org.eclipse.jetty.server.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:1040)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:592)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:214)
at org.eclipse.jetty.server.HttpConnection.handle(HttpConnection.java:411)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:526)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:41)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:528)
at java.lang.Thread.run(Unknown Source)
Powered by Jetty://
I tested both RC0 and RC1 of GN 2.10.
Any idea which would help to resolve this problem would be more than appreciated, since I would like to have GeoNetwork upgraded from my project.
Many thanks in advance,
Tomas
Ing. Tomas Kliment, PhD.
Contact information:
Private:
Juzna 4, 04801 Roznava, Slovakia
Tel: +421 907 232019
Tel: +39 389 4955 954
e-mail: tomas.kliment@anonymised.com
www: http://about.me/klimeto
Work:
Junior Researcher
The National Research Council
Institute of Marine Science, Venice, Italy
Hi Tomas,
2013/5/15 Tomas Kliment <tomas.kliment@anonymised.com>:
Dear developers,
The security layer was replaced by Spring Security in 2.9 [1] but the
login should be quite similar. You could mimic what the widget apps do
[2]. You could also use basic auth now like Talend Spatial [3] for
example.
HTH. Francois
[1] http://trac.osgeo.org/geonetwork/wiki/proposals/SpringSecurity
[2] https://github.com/geonetwork/core-geonetwork/blob/master/web-client/src/main/resources/apps/js/GeoNetwork/lib/GeoNetwork/Catalogue.js#L1137
[3] https://github.com/talend-spatial/talend-spatial/issues/8
<request>
<username>admin</username>
<password>admin</password>
</request>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1"/>
<title>Error 500 org.apache.jsp.login_jsp</title>
</head>
<body><h2>HTTP ERROR 500</h2>
<p>Problem accessing /geonetwork/login.jsp. Reason:
<pre> org.apache.jsp.login_jsp</pre></p><h3>Caused
by:</h3><pre>java.lang.ClassNotFoundException: org.apache.jsp.login_jsp
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
</pre>
<hr /><i><small>Powered by Jetty://</small></i><br/>
<br/>
<br/>
<br/>
<br/>
<br/>
<br/>
<br/>
<br/>
<br/>
<br/>
<br/>
<br/>
<br/>
<br/>
<br/>
<br/>
<br/>
<br/>
<br/>
</body>
</html>
Tomas
Private:
Work:
Junior Researcher
AlienVault Unified Security Management (USM) platform delivers complete
security visibility with the essential security capabilities. Easily and
efficiently configure, manage, and operate all of your security controls
from a single console and one unified framework. Download a free trial.
http://p.sf.net/sfu/alienvault_d2d
GeoNetwork-devel mailing list
