i'm having a problem with the conformity degree field (/gmd:MD_Metadata/gmd:dataQualityInfo/gmd:DQ_DataQuality/gmd:report/gmd:DQ_DomainConsistency/gmd:result/gmd:DQ_ConformanceResult/gmd:pass). I noticed that when i click the save & close button the field is not include inside the post call of the form.
This is the form field in the post call:
_X156_replace:<gmd:result xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:gn="http://www.fao.org/geonetwork" xmlns:gco="http://www.isotc211.org/2005/gco" xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:gmx="http://www.isotc211.org/2005/gmx" xmlns:srv="http://www.isotc211.org/2005/srv" xmlns:gml="http://www.opengis.net/gml" xmlns:xlink="http://www.w3.org/1999/xlink">
<gmd:DQ_ConformanceResult>
<gmd:specification>
<gmd:CI_Citation>
<gmd:title>
<gco:CharacterString>Commission Regulation (EU) No 1089/2010 of 23 November 2010 implementing Directive 2007/2/EC of the European Parliament and of the Council as regards interoperability of spatial data sets and services</gco:CharacterString>
</gmd:title>
<gmd:date>
<gmd:CI_Date>
<gmd:date>
<gco:Date>2010-12-08</gco:Date>
</gmd:date>
<gmd:dateType>
<gmd:CI_DateTypeCode codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/codelist/ML_gmxCodelists.xml#CI_DateTypeCode" codeListValue="publication" />
</gmd:dateType>
</gmd:CI_Date>
</gmd:date>
</gmd:CI_Citation>
</gmd:specification>
<gmd:explanation>
<gco:CharacterString>See the referenced specification 1</gco:CharacterString>
</gmd:explanation>
</gmd:DQ_ConformanceResult>
</gmd:result>
Instead this is the form field in the post call when i click the save metadata button:
<gmd:specification>
<gmd:CI_Citation>
<gmd:title>
</gmd:title>
<gmd:date>
<gmd:CI_Date>
<gmd:date>
</gmd:date>
<gmd:dateType>
</gmd:dateType>
</gmd:date>
</gmd:CI_Citation>
<gmd:explanation>
</gmd:explanation>
<gmd:pass xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:gco="http://www.isotc211.org/2005/gco" gco:nilReason="unknown">
<gco:Boolean></gco:Boolean>
</gmd:pass>
</gmd:result>
You can notice the tag gmd:pass is correctly popuplated in this call. There is a way to fix this?
Marco
This email was Virus checked by Astaro Security Gateway. http://www.sophos.com
