[GeoNetwork-devel] GN can run on Win XP, why cannot run on Linux?
Hi List,
I checked out the source code from geonetwork software subversion and built it. I can run on WinXP OS successfully. But,I cannot run the same version I built on a Linux OS (Cent 5.2 OS).
The error in output.log is as follows,
2009-12-23 14:43:32.653::INFO: Logging to STDERR via org.mortbay.log.StdErrLog
2009-12-23 14:43:32.872::INFO: jetty-6.1.14
Dec 23, 2009 2:43:38 PM org.geotools.data.shapefile.indexed.IndexedShapefileDataStore
SEVERE: null
Dec 23, 2009 2:43:39 PM org.geotools.referencing.factory.epsg.ThreadedHsqlEpsgFactory isAvailable
WARNING: Unavailable authority factory: European Petroleum Survey Group
org.opengis.referencing.FactoryException: Failed to connect to the EPSG database.
at org.geotools.referencing.factory.epsg.ThreadedEpsgFactory.createBackingStore(ThreadedEpsgFactory.java:428)
at org.geotools.referencing.factory.DeferredAuthorityFactory.getBackingStore(DeferredAuthorityFactory.java:132)
at org.geotools.referencing.factory.BufferedAuthorityFactory.isAvailable(BufferedAuthorityFactory.java:233)
at org.geotools.referencing.factory.DeferredAuthorityFactory.isAvailable(DeferredAuthorityFactory.java:119)
at org.geotools.factory.FactoryRegistry.isAvailable(FactoryRegistry.java:668)
at org.geotools.factory.FactoryRegistry.isAcceptable(FactoryRegistry.java:500)
at org.geotools.factory.FactoryRegistry$1.filter(FactoryRegistry.java:191)
at javax.imageio.spi.FilterIterator.advance(ServiceRegistry.java:793)
at javax.imageio.spi.FilterIterator.(ServiceRegistry.java:787)
at javax.imageio.spi.ServiceRegistry.getServiceProviders(ServiceRegistry.java:491)
at org.geotools.factory.FactoryRegistry.getServiceProviders(FactoryRegistry.java:196)
at org.geotools.referencing.ReferencingFactoryFinder.getFactories(ReferencingFactoryFinder.java:176)
at org.geotools.referencing.ReferencingFactoryFinder.getCRSAuthorityFactories(ReferencingFactoryFinder.java:451)
at org.geotools.referencing.DefaultAuthorityFactory.getBackingFactory(DefaultAuthorityFactory.java:88)
at org.geotools.referencing.DefaultAuthorityFactory.(DefaultAuthorityFactory.java:69)
at org.geotools.referencing.CRS.getAuthorityFactory(CRS.java:182)
at org.geotools.referencing.CRS.decode(CRS.java:420)
at org.geotools.referencing.CRS.decode(CRS.java:348)
at org.fao.geonet.kernel.search.spatial.SpatialIndexWriter.createFeatureStore(SpatialIndexWriter.java:397)
at org.fao.geonet.kernel.search.spatial.SpatialIndexWriter.(SpatialIndexWriter.java:127)
at org.fao.geonet.kernel.search.SearchManager$Spatial.createWriter(SearchManager.java:709)
at org.fao.geonet.kernel.search.SearchManager$Spatial.(SearchManager.java:693)
at org.fao.geonet.kernel.search.SearchManager.(SearchManager.java:142)
at org.fao.geonet.Geonetwork.start(Geonetwork.java:139)
at jeeves.server.JeevesEngine.initAppHandler(JeevesEngine.java:426)
at jeeves.server.JeevesEngine.init(JeevesEngine.java:146)
at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:66)
at javax.servlet.GenericServlet.init(GenericServlet.java:241)
at org.mortbay.jetty.servlet.ServletHolder.initServlet(ServletHolder.java:431)
at org.mortbay.jetty.servlet.ServletHolder.doStart(ServletHolder.java:263)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:50)
at org.mortbay.jetty.servlet.ServletHandler.initialize(ServletHandler.java:643)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:140)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1234)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:517)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:460)
at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:985)
at org.mortbay.start.Main.invokeMain(Main.java:194)
at org.mortbay.start.Main.start(Main.java:523)
at org.mortbay.start.Main.main(Main.java:119)
Caused by: java.sql.SQLException: User not found: SA
at org.hsqldb.jdbc.Util.sqlException(Unknown Source)
at org.hsqldb.jdbc.jdbcConnection.(Unknown Source)
at org.hsqldb.jdbcDriver.getConnection(Unknown Source)
at org.hsqldb.jdbc.jdbcDataSource.getConnection(Unknown Source)
at org.geotools.referencing.factory.epsg.ThreadedHsqlEpsgFactory.createBackingStore(ThreadedHsqlEpsgFactory.java:313)
at org.geotools.referencing.factory.epsg.ThreadedEpsgFactory.createBackingStore0(ThreadedEpsgFactory.java:384)
at org.geotools.referencing.factory.epsg.ThreadedEpsgFactory.createBackingStore(ThreadedEpsgFactory.java:421)
… 52 more
at org.geotools.factory.FactoryRegistry.getServiceImplementation(FactoryRegistry.java:436)
at org.geotools.factory.FactoryRegistry.getServiceProvider(FactoryRegistry.java:364)
at org.geotools.factory.FactoryCreator.getServiceProvider(FactoryCreator.java:143)
at org.geotools.referencing.ReferencingFactoryFinder.getAuthorityFactory(ReferencingFactoryFinder.java:216)
at org.geotools.referencing.ReferencingFactoryFinder.getCRSAuthorityFactory(ReferencingFactoryFinder.java:436)
at org.geotools.referencing.factory.epsg.LongitudeFirstFactory.createBackingStore(LongitudeFirstFactory.java:189)
… 63 more
at org.geotools.factory.FactoryCreator.getServiceProvider(FactoryCreator.java:224)
Any suggestion?
