[GeoNetwork-devel] GN on Ubuntu with PostgreSQL
Im installing geonetwork in Linux Ubuntu. I used the HowTO to perform this
task. I could lunch (Geoserver is working) and GN connects to to the DB.
<!-- Postgresql -->
  <resource enabled="true">
   <name>main-db</name>
   <provider>jeeves.resources.dbms.DbmsPool</provider>
   <config>
   <user>postgres</user>
         <password>my_password</password>
   <driver>org.postgresql.Driver</driver>
   <!-- URL :distant server -->
   <url>jdbc:postgresql://11.52.155.253:5432/my_database</url>
   <poolSize>10</poolSize>
  </config>
  </resource>
But, it does not work well. For ex: Categories are not displayed. Please
find below a piece of the log file:
2008-10-15 14:21:56,298 INFO [jeeves.request] -
2008-10-15 14:21:56,298 INFO [jeeves.request] - HTML Request (from
127.0.0.1) : /srv/en/main.home
2008-10-15 14:21:56,298 DEBUG [jeeves.request] - Method : GET
2008-10-15 14:21:56,298 DEBUG [jeeves.request] - Content type : null
2008-10-15 14:21:56,298 DEBUG [jeeves.request] - Accept :
text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
2008-10-15 14:21:56,298 INFO [jeeves.service] - Dispatching : main.home
2008-10-15 14:21:56,298 DEBUG [jeeves.service] - -> no input parameters
2008-10-15 14:21:56,298 INFO [jeeves.service] - -> dispatching to output
for : main.home
2008-10-15 14:21:56,392 INFO [jeeves.webapp.main.home] - Returning search
data
2008-10-15 14:21:56,407 DEBUG [jeeves.dbms.select] - Query : SELECT * FROM
Categories
2008-10-15 14:21:56,407 DEBUG [jeeves.dbms.select] - Found 12 records in 0.0
secs
CategoriesDes
2008-10-15 14:21:56,407 DEBUG [jeeves.dbms.select] - Found 40 records in 0.0
secs
2008-10-15 14:21:56,407 ERROR [jeeves.service] - Exception executing gui
service : java.lang.NullPointerException
2008-10-15 14:21:56,407 ERROR [jeeves.service] - (C) Stack trace is :
  at org.fao.geonet.lib.LocalLib.retrieve(LocalLib.java:216)
  at org.fao.geonet.lib.LocalLib.retrieve(LocalLib.java:124)
  at org.fao.geonet.services.category.List.exec(List.java:54)
  at jeeves.server.dispatchers.guiservices.Call.exec(Call.java:75)
  at
jeeves.server.dispatchers.AbstractPage.invokeGuiService(AbstractPage.java:119)
  at
jeeves.server.dispatchers.AbstractPage.invokeGuiServices(AbstractPage.java:104)
  at
jeeves.server.dispatchers.ServiceManager.dispatchOutput(ServiceManager.java:639)
  at
jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:382)
  at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:616)
  at jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:163)
  at jeeves.server.sources.http.JeevesServlet.doGet(JeevesServlet.java:88)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
  at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
  at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
  at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
  at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
  at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
  at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
  at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
  at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)
  at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:874)
  at
org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
  at
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
  at
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
  at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
  at java.lang.Thread.run(Thread.java:595)
2008-10-15 14:21:56,407 DEBUG [jeeves.dbms.select] - Query : SELECT uuid as
siteId, name FROM Sources
2008-10-15 14:21:56,423 DEBUG [jeeves.dbms.select] - Found 0 records in
0.016 secs
2008-10-15 14:21:56,423 DEBUG [jeeves.dbms.select] - Query : SELECT DISTINCT
id, changeDate FROM Metadata, OperationAllowed WHERE id=metadataId AND
isTemplate='n' AND operationId=0 AND (groupId=0 OR groupId=1) ORDER BY
changeDate DESC
2008-10-15 14:21:56,423 DEBUG [jeeves.dbms.select] - Found 0 records in 0.0
secs
2008-10-15 14:21:56,423 DEBUG [jeeves.dbms.select] - Query : SELECT * FROM
Regions
2008-10-15 14:21:56,438 DEBUG [jeeves.dbms.select] - Found 287 records in
0.015 secs
2008-10-15 14:21:56,501 INFO [jeeves.webapp.main.home] - Returning search
data
2008-10-15 14:21:56,501 INFO [jeeves.service] - -> transforming with
stylesheet : C:\workspace\my_database\web\geonetwork\/xsl/main-page.xsl
2008-10-15 14:21:57,110 INFO [jeeves.service] - -> end transformation
for : main.home
2008-10-15 14:21:57,110 INFO [jeeves.service] - -> output ended for :
main.home
2008-10-15 14:21:57,110 INFO [jeeves.service] - -> dispatch ended for :
main.home
Can anyone help me out to find what's happening?
Thanks.
Abel
View this message in context: http://www.nabble.com/GN-on-Ubuntu-with-PostgreSQL-tp19999805p19999805.html
Sent from the geonetwork-devel mailing list archive at Nabble.com.
Hi Abel,
Have you run GAST to populate the database? Having an unpopulated database might be one explanation for the error.
James Dempsey
Java Technical Lead
CSIRO IM&T Applications Group
________________________________________
Sent: Thursday, 16 October 2008 5:47 AM
To: geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] GN on Ubuntu with PostgreSQL
<!-- Postgresql -->
         <config>
        </config>
  </resource>
for : main.home
data
Categories
secs
CategoriesDes
secs
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
0.016 secs
changeDate DESC
secs
Regions
0.015 secs
data
for : main.home
main.home
main.home
Thanks.
Abel
Hi James and thank you for answering
Yes I did run Gast and populate the DB. I can see in the log-file that GN is
performing successfully some queries.
That's why I'm perplex.
Thanks.
Abel.
James.Dempsey wrote:
Hi Abel,
James Dempsey
Java Technical Lead
<!-- Postgresql -->
         <config>
        </config>
  </resource>
output
for : main.home
data
Categories
0.0
secs
CategoriesDes
0.0
secs
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
as
0.016 secs
DISTINCT
changeDate DESC
0.0
secs
Regions
0.015 secs
data
transformation
for : main.home
main.home
main.home
Thanks.
Abel
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the
world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
GeoNetwork-devel mailing list
View this message in context: http://www.nabble.com/GN-on-Ubuntu-with-PostgreSQL-tp19999805p20001412.html
Hi Abel,
Not sure if this is applicable as its a while since I tried it but I couldn't get the postgres 8.x jdbc drivers to work with GeoNetwork. However as I recall GeoNetwork with the 7.4 jdbc3 drivers did work.
Simon
Sent: Thursday, 16 October 2008 7:14 AM
Subject: Re: [GeoNetwork-devel] GN on Ubuntu with PostgreSQL
Thanks.
Abel.
Hi Abel,
James Dempsey
Java Technical Lead
<!-- Postgresql -->
         <config>
        </config>
  </resource>
output
for : main.home
data
Categories
0.0
secs
CategoriesDes
0.0
secs
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
as
0.016 secs
DISTINCT
changeDate DESC
0.0
secs
Regions
0.015 secs
data
transformation
for : main.home
main.home
main.home
Thanks.
Abel
challenge
prizes
world
geonetwork-devel List Signup and Options
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
