I am a relatively new convert to the GeoNetwork (on 2.6) and presently
setting up a server in the UK but have been having issues with the crs code
used in <proj>, I think this is where I need to make the changes but please
correct me if wrong!
What I am trying to do is to project the data in the "mapViewer" and
"mapSearch" (within config-gui.xml) in a projection other than epsg:4326,
which for my region is epsg:27700 (the UK), so that when a viewer looks at
the map the data are projected in a manner familiar to the viewer. However,
when I set the crs code to 27700 I find that the map elements of GN do not
load. I would be very grateful if somebody could please assist as I have
tried many different options and appear to be getting nowhere - are there
some other files that I should be modifying?
Many thanks in advance for any assistance with this.
Mark
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GN2-6-and-geoserver-srs-codes-tp5650881p5650881.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
